relay for head lamp switch - Defender Source
Old August 28th, 2008, 12:02 AM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
I have just replaced my second head lamp switch in my 11 year old truck.... I have just tried build to a harness and install a standard 12 v 30 amp automotive relay ... but I am stuck and need some help to make it work... has any one put together a workable design? I am assuming the brown lead is "power in" and the red lead turns on running lamps and the blue lead tuns on head lamps. My relay has 4 tangs - #30 is power in. #85 is ground - #86 is a Trigger and # 87 is the lead to the lamps (low beam). can anyone draw me a picture of how I should build the harness between the plug for my switch and the harness under the instrument cluster.
Many thanks
lamp, relay, switch
Need help wiring genuine fog lamp switch and Hellas fleabus Defender Technical Discussions 1 May 21st, 2006 02:00 PM
Reverse Lamp Switch Wiring fleabus Defender Technical Discussions 7 April 16th, 2006 11:58 AM
Fuel Pump, Switch, Relay, or Wiring? bbandit Defender Technical Discussions 19 July 10th, 2005 12:08 PM
