Rehabbing my tub - Defender Source
Old July 2nd, 2013, 10:31 AM
boswalt's Avatar
boswalt
Brian Oswalt
1988 exmod 110
Rehabbing my tub
Previous owner put in a roll on bedliner on my exmod 110. It's flaking in some spots and hardened like cement in others. Tub went out to the blasters but he couldn't get much out without risking warping the aluminum.
Grinding, wire wheels etc just seem to melt the stuff, filling up the wheel.
Next step is some aircraft stripper but testing a small patch didn't get the results I was looking for......
I'm at the point where chequer plate bed protector is looking good.....I hate chequer plate but thist stuff is a pain in the butt.
Any ideas?
Old July 2nd, 2013, 10:56 AM
ezzzzzzz
Mark Garrenton
Dry ice and scrapping will likely be required. It's used by others with old factory noise barrier materials. Sometimes you can smack it a hammer after freezing to pop it loose but you'll definately risk damaging the aluminum if you do. It's a slow process. Watch for frost bite.
Old July 2nd, 2013, 11:30 AM
I see two options:
1. Buy a new tub
2. Embrace the bed-liner and re-spray
Old July 2nd, 2013, 01:55 PM
mattarm's Avatar
mattarm
Matt
1993 D110
I tried the dry ice on my dynamat and it did not work at all. I don't know if it is just the difference between the aluminum and steel or what. Most of what I saw online looked pretty easy. Most of my experience was frustration. Not that it would work on your bedliner, but I wound up using a citrus based solvent and lots of elbow grease. If I had to do it all over again, I simply would have replaced the entire floor as I burned about 60 hours and who knows how much on various materials and experimentation.
rollcage,ARB's, 4.10's GBR, badger, D90 tub Shane@EVS For Sale - Parts 20 March 20th, 2006 06:41 PM
need New D-90 Tub for 94 defender hutclose Wanted 2 September 13th, 2005 06:48 PM
SW driver/passengerside doors wanted as well as centor console tub jchan88 Wanted 4 August 7th, 2005 09:04 PM
?? tub anchor point - needed?? paulb Defender Technical Discussions 3 June 23rd, 2005 01:02 PM
tub width on a '94 D90 is tapered "natural"? paulb Defender Technical Discussions 3 August 18th, 2004 07:07 PM
