Refinishing Brushbar and Bumper - Defender Source
Old November 17th, 2013, 04:17 PM
61rover's Avatar
61rover
John Crouse
I need to refinish my brushbar and front bumper. What's the best route? Looks like Powdercoat on the brushbar and paint on the bumper. Powdercoat both?
Also, a mechanic dented the brushbar while it was in his shop. Is there anyway to repair the dent and still have the powdercoating stick? See the picture.
And last, what percent gloss is correct for the brushbar. All help is appreciated.
Old November 17th, 2013, 06:31 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Are you repainting yourself or taking it off and sending for powder coat?
Reason I ask is what level finishing do you want?. Spot repair or re-paint whole brush bar?
Old November 17th, 2013, 08:44 PM
Once rust gets under powder coat it all has to come off and be refinished however you like.
Old November 17th, 2013, 08:52 PM
rovertrader's Avatar
rovertrader
Dale
Burn off existing coating, sand blast, then either PC or acid etch prime/paint
Old November 17th, 2013, 10:32 PM
61rover's Avatar
61rover
John Crouse
The brushbar needs to be blasted and refinsihed. There is more finish coming off than just the dent. It won't kill me to just leave the dent and powdercoat it but wanted to know the options.
Old November 18th, 2013, 11:21 PM
Green Blood's Avatar
Green Blood
Carl Phillips
1988 90- Swiss LHD 2.5 Petrol
For your dent repair, check out a product called Alvin Lab-Metal: (http://www.alvinproducts.com/)
It's a body filler that contains metal and can withstand the heat of powder coating. I used when restoring a motorcycle and was pleased with the results. Just apply and sand to a final finish once dry and then have your part coated.
Good luck!
Proud restorer and former owner of '94 NAS D90 #590- back in the hands of its original owners.
And now happy owner of a 1988 Swiss-Market D90 Station Wagon.
Old November 19th, 2013, 12:56 AM
jafir's Avatar
jafir
Jafir Elkurd
Hard to tell how big that dent is. If its small, you can weld it than smooth it back out with a flap disc. If its big, not much you can do. possibly replace the section. Welding wont be an option though if you are going to galvanize it. -Jeff
I know you aren't supposed to weld galvanized metal because release fumes, but why can't you galvanize welded metal?
Old November 19th, 2013, 01:12 AM
jafir's Avatar
jafir
Jafir Elkurd
Very interesting. This is why I like this site. Thanks.
Old November 19th, 2013, 09:50 AM
Briggs, you have crazy eyes. I can't see that. There's a ton of welding on all my stuff that's been dipped and I cannot see any difference between welded and not welded in the zinc.
Well, except for the snotty goobers of weld spatter that give it away....
Old November 19th, 2013, 11:19 AM
61rover's Avatar
61rover
John Crouse
Good luck!
Cool. I'll check it out!
Old November 19th, 2013, 11:52 AM
RobTheGob's Avatar
RobTheGob
Rob
1963 IIa 88 & 1995 NAS D-90 SW
The powder coat on my push bar had rust underneath in many spots. I removed it all and covered it with some good primer and then flat black rust paint.
IMO - looks better than the powder coat and *way* easier to maintain...
bumper
Winch bumper jjstahl3 Wanted 12 January 18th, 2011 05:15 PM
FS: NEW Warn 9.5ti with custom bumper mpodgorski For Sale - Parts 10 November 2nd, 2010 07:22 PM
Winch Bumper Stmpede Wanted 15 November 5th, 2008 08:18 PM
Factory looking winch bumper help shawnpalmer Defender Technical Discussions 19 January 21st, 2007 06:30 AM
90 brushbar/lightbar/bumper assembly mpodgorski For Sale - Parts 15 February 9th, 2006 04:42 PM
