red plug behind master cylinder - Defender Source
Old January 30th, 2010, 12:41 AM
imeek
Isaac
Red 94 D-90 (SOLD)
I looked through my manual and on-line at rovers north, but couldn't figure out what this plug is for. Should it be connected to anything?
Thanks for your help.
Old January 30th, 2010, 08:16 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Fluid level ?
- Charles Eames
Old January 30th, 2010, 10:16 AM
A close up would be better - what is it connected to? Is it integrated into the wiring harness? The only thing I can think of with red plugs are washer jet connectors, but the 94 might not have even had that type. Seems non-stock at first glance, but only more detailed pix could tell.
Old January 30th, 2010, 10:45 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Its a late model clutch master from a Td5 style Defender. They have a fluid switch built in. So what it means is that someone replaced your clutch master with a later model part. It isn't really "wrong" because the clutch master will work and do the exact same job as the NAS part, it just has that outlet in it with the location for the wiring.
In a NAS car that switch is not there, so nothing should be plugged into it. No worries.
Email:
Old January 30th, 2010, 10:52 AM
imeek
Isaac
Red 94 D-90 (SOLD)
Muchas gracias. Thank you, I was really stumped (as I couldn't find it in any of my manuals).
Old January 30th, 2010, 04:36 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
We still need a close up shot.
I have a late model and i don't have a fluid switch.
I thought it was a NAS thing.
- Charles Eames
Old January 30th, 2010, 07:25 PM
ECR's Avatar
ECR
Not an NAS thing.
It has to do with the ABS/TC system, so not every truck has it.
Email:
Old January 30th, 2010, 09:11 PM
imeek
Isaac
Red 94 D-90 (SOLD)
A closer picture is going to take me a week, as the truck is at the shop (and I'm headed to Africa for a week). I'll post up when I get back.
master
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
Brake Master Cylinder Leak chris snell Defender Technical Discussions 12 September 28th, 2011 09:50 AM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
