Red Line Gear Oil... - Defender Source
Old October 19th, 2008, 08:47 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Question Red Line Gear Oil...
Need help on what weight to use for transmission. Can someone here please help?
RedLine Gear OIl...
75W90
SuperLight Gear Oil
75W140
80W140
75W90 NS
75W140NS
LightWeight Gear Oil
Limited Slip Friction Modifier
V-Twin Primary Case Oil
Weldon
Weldon
Old October 19th, 2008, 09:02 AM
Mtl.
http://www.defendersource.com/forum/...ht=Redline+MTL
http://www.defendersource.com/forum/...&highlight=MTL
Old October 19th, 2008, 10:05 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Phillip,
Straight MTL?
Got it...
And for others who would like to know it's 70W80 GL-4 Gear Oil (SAE 5W30/10W30 engine oil viscosity).
Weldon
Old October 19th, 2008, 11:45 AM
Straight MTL, do you have an AA yellow ST?
Old January 1st, 2009, 01:18 PM
Grover's Avatar
Grover
Question
Phillip,
Is this the MTL oil you use in your truck?
http://www.jegs.com/i/Red+Line+Oil/816/50204/10002/-1#
Red Line oil #816-50204
Synthetic Manual Transmission Lubricants
70W80 GL-4
Cheers...
Old January 1st, 2009, 07:28 PM
Yup.
Old January 1st, 2009, 09:03 PM
I bought soome from a vendor on ebay for $8 a quart. MTL stands for Manual Transmission Lube and its great in most any manual tranny.
Old January 1st, 2009, 09:20 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I used to use the GM synthetic synchromesh oil in my 90, worked great and was readily available from any dealer. Cost a fortune, though.
Old January 2nd, 2009, 03:42 PM
mikeybob2@msn.com's Avatar
mikeybob2@msn.com
Michael Sabanovich
1994 Defender 90 #1880
How many quarts does an R380 hold?
Old January 2nd, 2009, 07:10 PM
I think 3, I usually buy four and have a little left over for keeping it "topped up".
Old January 2nd, 2009, 09:50 PM
mikeybob2@msn.com
Michael Sabanovich
Thanks,,, I was thinking 3 but I'll get 4. I finally found a supplier for Redline products here in Houston( http://www.proamauto.com/page13e.htm ). It's hard to believe that I could only find one vendor in the 4th largest city in the US and I'm glad I did.. They carry all the Red Line products and have it all in stock.. and a lot of other good stuff...
Old January 3rd, 2009, 01:32 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
How well does this fluid deal with extreme heat?
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 5th, 2009, 09:18 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
From RedLine's Web Site:
'Red Line's motor oils and gear oils use superior ester base stocks that provide extreme stability at high temperatures and superior film strength at lower viscosities..'
~Scott T.
'95 D-90 ST - AA Yellow
Old January 5th, 2009, 09:51 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Thanks, but I was thinking about the MTL.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 6th, 2009, 08:50 AM
WHat are you currently using in the extreme heat?
Old January 6th, 2009, 09:00 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
MTL is a Gear Oil , 70w80 GL-4 rated. Maybe I'm missing something..
~Scott T.
Old October 28th, 2009, 11:14 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Should I use Red Line MTL for the Differentials and Transfer case as well or is there a more appropriate Red Line Gear oil to use for those?
Old October 28th, 2009, 12:14 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
NO, you SHOULD NOT use MTL in the transfer case and differentials. MTL is a GL4 rated gear oil, you need a GL-5 rated gearoil in the transfer case and differentials. Use Redline 75W90 to go by the book.
For what it's worth, I ran Redline's 75W140 in my Discovery and Defender diffs and transfer case, but I'm going to switch the Defender over to their Heavy Weight ShockProof in the spring..
~Scott T.
Old October 28th, 2009, 01:19 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks Scott. I didn't think so, which is why I asked. I was going to buy the 75W90 but what stopped me was this quote from their site: "This product is not designed for use in most manual transmissions or tranaxles, since the extreme slipperiness may cause synchronizer mesh issues that lead to shifting problems"
That just means, don't use it for the gearbox, right?
What is the difference between the 75W90 and the 75W90NS?
And was there any difference for you using the 75W140 or the shockproof kind?
Old October 28th, 2009, 01:45 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
GL4 is fine for transfer case, diffs, swivel housings and hubs, provided it's formulated for them, which the MTL is not.
The older GL5 formulations would in fact attack brass/bronze components but I've read, but not confirmed, that the newer formulations of GL5 don't do that. I used 75w140 GL4 for years, until I couldn't get it anymore.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Oil Cooler Line Orientation Question dnewman9 Defender Technical Discussions 3 April 9th, 2011 06:24 PM
