RED HOT exhaust - Defender Source
Old February 17th, 2016, 12:31 PM
DocB
David
1989 D110
RED HOT exhaust
After my head gasket replacement last week, I invented an exhaust gasket out of the bottom of a Coors Light can. Just until the legit gasket comes in from the UK. Well I'm pretty sure that it melted today. Popped the hood after about 15 minutes of highway driving to find that my exhaust manifold was GLOWING red hot. I've never seen this before? Coolant/oil temps and pressure was normal. Car running fine, minus the small exhaust leak that developed only about a minute before I pulled off the highway.
Photo attached, your thoughts?
Old February 17th, 2016, 12:33 PM
Blocked cats?
Old February 17th, 2016, 12:38 PM
DocB
David
1989 D110
"Custom" gasket lol
Old February 17th, 2016, 12:42 PM
DocB
David
1989 D110
Almost looks original!
Old February 17th, 2016, 12:47 PM
DocB
David
1989 D110
On the car...
Old February 17th, 2016, 12:54 PM
MisterSHO
David K
87 110, 95 RRC
Love this. I'm gonna go crush a six-pack juuuuust in case.
Old February 17th, 2016, 12:59 PM
DocB
David
1989 D110
Blocked cats?
Definitely don't have a cat lol
1989 ex-mil petrol
Old February 17th, 2016, 01:09 PM
Blocked exhaust or you are running way out of tune.
Old February 17th, 2016, 01:18 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
In all my years of vehicle ownership I can honestly say I have never seen that before, even running rich would produce a fuel smell, you sure you aren't running it in low gear or something?
Old February 17th, 2016, 01:19 PM
red hot exhaust manifold is a sign that timing is way retarded.
Old February 17th, 2016, 01:20 PM
Exhaust runs hotter than the melting point of aluminum so it is not the best option for an exhaust gasket......
What engine are we talking about? 2.5 petrol?
Old February 17th, 2016, 01:21 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Could it be the aluminum gasket?
Aluminum Glows
Old February 17th, 2016, 01:38 PM
DocB
David
1989 D110
Yup 2.5 petrol. Stock motor, nothing special. I wasn't expecting too much life out of the bee can gasket lol. Just crossing my fingers until the correct part gets here from the UK.
Even if it did melt it, I've never seen a manifold get that hot from simply driving on the highway
------ Follow up post added February 17th, 2016 10:42 AM ------
Not going to lie, but I tuned it by ear and I'm not a super expert with tuning by ear. I did retard the timing a bit yesterday to lower the idle. It was WAY high and not correcting enough by adjusting not the mixture
Old February 17th, 2016, 01:45 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Is there not an idle speed adjustment on the carb?
Old February 17th, 2016, 01:51 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
As UD said: Timing is way off.
As John said: Aluminum is not an acceptable material for any part of an exhaust system.
I think I posted how to time your engine.
Did you read that?
You can use the same procedure to check your timing without running the engine.
Are the weights and springs in your distributor moving freely when you manually twist the rotor?
Don't twist too hard as the rotor is plastic and can break off.
RDavisinVA
Old February 17th, 2016, 02:01 PM
On the timing.... Get a timing light and tach and check timing versus engine speed and make sure it is in spec per the manual.... Before you do another head gasket or worse.
If it is not the timing or a restriction in the exhaust, it is running lean.
Old February 17th, 2016, 02:10 PM
bish1865
Bruce Bishop
1985 Defender 110
If the 2.5 gas uses the same size exhaust as 2.5 NA diesel. I found like replacement at Riebies auto parts. I brought my old one in and they matched it. I don't recall what auto used a similar gasket. But what they gave me lasted 2 years until I removed the engine. Saves waiting for parts out of the UK.
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Which may have contributed to the head gasket failure...?
Email is
Same place, new dogs.
Old February 17th, 2016, 10:18 PM
DocB
David
1989 D110
There is a set screw with a spring behind it on the side of the carb that I believe sets the mixture. Is there two screws? (I.e. One for mixture and one for idle speed)
------ Follow up post added February 17th, 2016 07:19 PM ------
Set the mixture more rich and advanced the timing, seems to be running a lot better and more smooth. Got a timing light on my way home and I'm about to go check it out
Old February 18th, 2016, 12:57 AM
DocB
David
1989 D110
Ok, I found the manual for tuning the carb. Started by setting the timing to 0degrees at idle. (No tach to set it under load). Made sure that the choke was functioning. Set idle speed to 6-700 RPMs (estimate) and started to adjust the mixture screw. No change. I'm beginning to think that this is a carb issue. Like I need a new carb issue lol.
Also noticed something that seems weird. So I pulled off the top elbow to look down the barrels. One of the barrels looks completely unused. It I press the throttle, no fuel squirts in there. The butterfly is closed and the barrels looks clean and brand new. Playing around with levers, there was no way that I could get the butterfly to open at all. Someone please educate me if this is normal or not!
exhaust
Red SW with red wheels bjf Misc. Chit-Chat 12 April 10th, 2008 12:55 AM
A/C Help......hot, hot, hot! boulderbear Defender Technical Discussions 7 August 26th, 2006 07:54 PM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
Superlift ORV Park in Hot Springs, Arkansas Nov. 20-23 Joe B Trips, Trails and Events 5 November 12th, 2003 10:07 AM
Hot/Cold - Blue/Red Heater control cover SFD90 Defender Technical Discussions 5 October 21st, 2003 06:31 PM
