Recovery points on LR winch bumper? - Defender Source
Old October 10th, 2005, 10:26 AM
jam90
JAMES MARKS
1995 D90 NAS ST #2043
I'm looking for some advice on where to mount front recovery points on an OEM Land Rover winch bumper on a D90.
Which bolts... if any... are solid enough for this application?
-James Marks
Old October 10th, 2005, 11:49 AM
Cube II's Avatar
Cube II
Michele
1997 D90
James,
where are you going to mount the recovery points on your bumper?
Are those which mount on top (a la Series) or like these?
So to go "in line" with the chassis?
A backing plate (as shown) is at least recommended,
assuming your bumper is thick enough.
I had made mine and welded directly on my custom bumper.
Pre-cutted shackle hangers from Rockstomper i.e. are also available,
so no bolts are needed
Cheers!
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old October 10th, 2005, 02:35 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
get Jate rings, they bolt to the chassis where the shipping tie down ring is.
Old October 10th, 2005, 03:02 PM
jam90
JAMES MARKS
Thanks for the advice...
it looks like those Jate rings will work great...
I can probably use them on the rear bumper as well.
-James
Old October 10th, 2005, 07:04 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
The only problems with Jate rings is that they get burried in mud before the bumper mounted recovery points.
Old October 11th, 2005, 04:34 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Yup.
This makes you swear and dig trying to reach them.
Michele
D90 VNTdi
[O]===[O]
Old October 12th, 2005, 02:18 AM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Those JATEs are actually rock sensors, but everyone thinks they are recovery points.
Use Dixon Bate tow jaws (expeditionexchange.com). The only proper kit.
But you may need to upgrade your stock bumper if you ever use them. John (EE) sells a backing plate for them. They go on each side of the basket (if there is one with an angle on that thing), or just outside of them maybe 3", but people tend to regret that as they can pull the bumper ends forward.
Old October 12th, 2005, 10:28 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
I have a LR winch bumper and you could mount them on the winch tray, but it is not a good idea IMO. I use tow hooks - because they came with the truck and I am too lazy to revisit the topic.
Dixon bates as the only proper kit? That's an EE fashion statement if I ever heard it.
EwS
Old October 12th, 2005, 11:44 AM
jam90
JAMES MARKS
Eric -
Where are the tow hooks mounted on your LR Winch bumper?
Can you post a photo?
Old October 12th, 2005, 12:52 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
I don't have any photos.
Hooks are frame mounted.
EwS
Old October 12th, 2005, 05:25 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
"Use Dixon Bate tow jaws (expeditionexchange.com). The only proper kit." ??
Yes that statement has a Torrence Ca. ring to it, even if it didn't have the parenthetical note.
Old October 12th, 2005, 05:57 PM
they mount below, the hooks that is.
Old October 12th, 2005, 08:33 PM
Troys
Troy Smith
1995 D90 SW
James
I to have the factory winch bumper. It came with two hooks that mount below the winch tray. Each hook mounts with two bolts each. AB advertises them as Warn Tow Hooks $29.95 for the pair. The Northern Store here locally sales them too. They can also be seen on the awsome white 1995 D90 SW pictured on the cover of the July issue of LRM. That is one great looking truck...
Hope that helps!
Troy
Old October 12th, 2005, 09:18 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Go DB hooks suck.LOL!! I have ruined a couple of straps from them falling off hooks at the wrong time. The hook pierced the strap at the loop. They have a tendency to bend & break as well. I have broken one. Positive anchor with the DB. I have swivel eyes on the Disco so far so good.
Old October 13th, 2005, 09:35 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
The hooks are less than optimal, but I rarely use them anyway. That's why I have a winch. I think the DB's have they're place, but there are definetly other options.
EwS
Old October 13th, 2005, 06:20 PM
johnlee
John Lee
EwS
How did EE get dragged into this? If we truly believed DB's were the only way to fly, then why would we sell hitch pins, safety tow hooks, JATE Rings, transit clusters, SMB's, receiver shackle brackets, and so on?
Old October 13th, 2005, 09:52 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Although both questions appear rhetorical, I'll answer reputation and selection, respectively.
Old October 18th, 2005, 03:43 AM
Broke It
Dave Butler
99 disco
Ships Mechanical has moab winch bumpers designed for rovers 1 (503) 252-5556 ask for Doug or Neil. these bumpers do not bend or break. the recovery points are welded inside and out. I used my bumper for moving large boulders and fallen trees. You can also see them at recoverygear.com
Old October 18th, 2005, 08:06 AM
These ones
http://www.recoverygear.com/smsi.html
bumper, cover, winch
WANTED. '94 lr hd winch bumper scout x Wanted 0 January 1st, 2006 09:10 AM
Heavy Duty winch bumper for 90/110 k4rovers For Sale - Parts 2 December 28th, 2005 01:06 AM
Safari Gard winch bumper and winch m016324 For Sale - Parts 3 September 20th, 2005 09:52 PM
D-90 Winch Bumper Capt Milks For Sale - Parts 0 August 27th, 2005 08:35 AM
Custom winch bumper Jase For Sale - Parts 5 August 19th, 2005 05:27 PM
