Recommended Lubricants and Fluids - 1990 200 TDI Defender - Defender Source
Old March 30th, 2016, 10:10 AM
LRColorado
1990 Defender (200 TDI)
I have an old service manual from the 90's, but I am looking for a webpage or feedback from members on recommended lubricants and fluids for my 1990 200 TDI Defender (124,000 miles).
  1. Engine
  2. Gearbox/Transfer
  3. Differentials
  4. Steering Box
  5. Clutch & Brakes
  6. Coolant
  7. Grease for grease fittings on drive shaft, etc.
  8. Ball Joint Assembly
Also, which drain plugs need copper washers?
Thanks for your help.
Old March 30th, 2016, 10:17 AM
*Engine
Any diesel engine specific oil. xW40 viscosity. If cold starting in the winter, one of the synthetic 0W40 or 5W40 is a good idea. Otherwise any 15W40 is fine.
*Gearbox
Redline MTL
*Transfer
*Differentials
Any regular gear oil. xW90
*Steering Box
ATF
*Clutch & Brakes
DOT 3 or 4
*Coolant
Regular coolant
*Grease for grease fittings on drive shaft, etc.
*Ball Joint Assembly
Something that resembles grease.
Old March 30th, 2016, 10:27 AM
LRColorado
Thanks John,
Can you also tell me which drain plugs need copper washers?
Can I go to the local auto parts store to buy them or do they need to be specific to my vehicle?
Old March 30th, 2016, 11:11 AM
Gearboxes and engine. They should be available locally. In forty years, I've never seen a need to change a sump washer on any car.
Old March 30th, 2016, 05:03 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
I suspect part of your question is, WHICH drain plugs need copper washers? The only one I can think had one is the engine oil drain.
Which fluids? Many people on this Forum like Shell Rotella for diesels. Widely available including Walmart & Kmart at about $14.00 per gallon.
These Rover manual transmissions originally called for automatic transmission fluid. Current opinion is modern ATF isn't the same as it was 20 years ago. As already mentioned, Red Line MTL is widely used on this Forum. (Unlike Rotella, it's expensive, I think I paid $15 per bottle.) DON'T use 'gear lube' in Defender manual transmissions.
For the other fluids, use your favorite brand, synthetic or not.
Originally Posted by LRColorado View Post
Thanks John,
90, defender, tdi
1990 110 5 door 200Tdi - First Registration December 1990 aaaja For Sale - Vehicles 7 October 19th, 2016 03:32 PM
1990 Defender (200 TDI) - Few questions from a newbie LRColorado Defender Technical Discussions 7 March 30th, 2016 10:53 AM
Used Proline 200 TDI Radiator & 200 tdi intercooler mgreenspan For Sale - Parts 4 April 8th, 2014 03:38 PM
Lubricants again o2batsea Defender Technical Discussions 4 October 24th, 2013 02:39 PM
Whaer can i get fluids for a defender? (fluids, oils, etc.) Landyman1 Defender Technical Discussions 10 May 25th, 2013 12:08 PM
