reciever electrical problems - Defender Source
Old March 11th, 2004, 07:03 PM
yellowrover's Avatar
yellowrover
Mike Holland
'97 AA Yellow D-90 ST
I have a 97 d-90 that has problems with my reciever's memory not working, everytime i turned off the car the settings were set back to default, i decided to just use the quick way out and ran a fused wire to the battery. every 3 days my battery died so that didn't work, so i went back to checking out the wiring, purple is the 12v and the purple/yellow is the switched 12v.....the only problem is that those have no juice going to them. I looked at the fuse panel behind the diff. lever and there was a 7.5 amp fuse that was blown and looking at the diagram looked like a picture of some radio that it went to, well i replaced that but still nothing happened. So can anyone give me any ideas for where i should start??? By the way there is a white wire in that cluster of wires that gives me juice but i didn't think it was the right wire to use..... any help would be great.
-Mike
Old March 12th, 2004, 07:07 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
I don't know, but do you know how to remove the radio from a '97?
Old March 13th, 2004, 11:41 AM
One of the wires the non switched one should have power going to it all the time. When you turn on the 90 one of those wires should have 12 Volts on it, that is the switched wire. The other wire should run directly to the battery.
I have no clue on the 97 radio removal. I would have to see one.
Old March 13th, 2004, 06:56 PM
yellowrover
Mike Holland
the purple is the 12v constant adn the purple/yellow is the 12v switched but they aren't getting any power at any time, even with the car turned on
Old March 15th, 2004, 12:30 PM
So the Radio does not work at all?
When you measure the voltage you are at a good ground point for the negative side of the meter? I know sometimes you will get bad measurements if you don't get a good return path to the meter.
Old March 16th, 2004, 06:21 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
My radio does the same thing. I have a pioneer cd player that resets everytime i turn the vehicle off. I hope i can figure it out when i replace it with my Alpine.
waveridin1959
Brian Jones
1995 D-90 ST #2892
Old March 17th, 2004, 05:13 PM
Has anyone had a look here?
http://www.defendersource.com/faq/In...adio.html#Pins
electrical, problems
Electrical Problems Galore- Coil, MAF Sensor, Wipers, Fuel Pump, Short Heath Defender Technical Discussions 10 August 28th, 2008 05:52 PM
Experiencing wierd electrical problems, engine power issues? madcowdungbeetle Defender Technical Discussions 0 May 26th, 2008 10:14 PM
Rear Door Electrical problems, what first? Hammertime Defender Technical Discussions 2 August 5th, 2007 01:01 PM
HELP! Indicators, Dash, Electrical Problems minorthreat Defender Technical Discussions 3 April 11th, 2007 09:19 PM
Electrical for beginners paulb Defender Technical Discussions 5 October 18th, 2004 01:58 PM
