Recaro Cross Sportster seats install - Defender Source
Old January 27th, 2014, 10:05 PM
defender1844
Amit Likhyani
Has anyone made brackets to mount these into a NAS Defender? Obviously the European Defenders have brackets(www.tunemydefender.com). Would those brackets work on our trucks? I have the brackets already and the seats will be here in a couple of weeks. It looks like when matched up against the factory runners the brackets do line up but the back of the bracket hangs out past the back or the rear bulk head. Has anyone tried this setup out or have any thoughts? There is a kit to make the bases removable which is cool.
Old January 27th, 2014, 10:21 PM
Photo might help ...
Old January 28th, 2014, 07:01 AM
myoverlandrover's Avatar
myoverlandrover
josh
109
I have not seen NAS brackets only European. But should be straight forward for someone with cad/solidworks and an water jet. A friend had
recaro to Miata brackets done for around 200$ locally. Love these seats and would be interested in hearing how you like them after some seat time. They are on my list to do
Defender 110
Old January 28th, 2014, 03:31 PM
USLandy's Avatar
USLandy
Andrew
defender 90
Pic would be good... I put a set of OMP seats in my 90; I took the OMP seat mounts and welded on some steel plate to the bottom. I then drilled holes to match the existing bolt holes for the standard defender seats. Simple as long as you have a welder and grinder.
Old January 28th, 2014, 04:47 PM
Ben01
Ben
Defender
http://www.tunemydefender.com/interi...on-seat-detail
they are selling an adapter kit as well
------ Follow up post added January 28th, 2014 04:57 PM ------
http://www.lrisolutions.co.uk/index....up-bases.html#
seems like this is the closest recaro seat to the svx model
seats
Exmoor Trim USA new middle row 110 seats sneak peek ExmoorTrimUSA The Vendors Loft 32 November 18th, 2013 09:20 PM
Recaro Trend Seats, Jump seats, bench seats, Exmoor tbutzow For Sale - Parts 1 June 12th, 2007 04:39 PM
Rf Rack install ? front cross bar placement paulb Defender Technical Discussions 0 June 12th, 2005 03:52 PM
Anyone want to trade their Stock front seats for Recaro seats? arbik For Sale - Parts 10 March 11th, 2005 10:42 PM
FS: Four SW Jump Seats from 95 D90 DJ Menasco For Sale - Parts 4 December 19th, 2003 12:28 AM
