rebuilt ECU's - Defender Source
Old February 4th, 2004, 12:02 AM
ttegt's Avatar
ttegt
Thomas Tegtmeier
1995 Defender 90
Unhappy rebuilt ECU's
I have a 1995 d-90 soft top, that has been diagnosed with a bad ecu. Checking land rover England, and land rover north America, new ones are months away, rebuilts are not to be found, salvage ones ore tough to locate. does anyone know where one can be rebuilt. My d-90 is more than a bear to start on cold mornings. once started runs GREAT!!!!. We have checked, I believe everything, and only by borrowing a friends ecu does the d-90 cold start easier. [FONT=courier new][FONT=times new roman][COLOR=crimson]
Old February 4th, 2004, 09:49 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Wasn't their a service bulletin about the cold start prom needing to be replaced on '97's and '95's? Thomas, you might send John Robison an email (of Robisonservice.com). He's very knowledgable in the Defender ECU space.
Old February 5th, 2004, 12:07 AM
ttegt's Avatar
ttegt
Thomas Tegtmeier
1995 Defender 90
Wink
I sent e-mail as you suggested, Thanks for your help.
Old February 5th, 2004, 12:28 AM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
There is a service bulletin about cold start issues, I just went through this. I purchased the E-prom a month ago and had it installed. Rover Connection sells it for $13 or you can get it from a LR dealer for about $26. There is a long thread on this from about a month ago.
Old February 5th, 2004, 11:34 PM
Neo
Jeffrey Rosbrugh
95 D90 ST #2585
Unfortunately, I must have been a sleep during the last thread. I find this interesting. Is there any way to determine by checking/looking if the EPROM has been changed already by the PO? So far, I have not expereinced any cold start issues, but then I don't live in a really cold area either. Are there other advantages to changing the EPROM?
Thanks!
Jeff
Pain is weakness leaving the body
Old February 5th, 2004, 11:59 PM
ttegt's Avatar
ttegt
Thomas Tegtmeier
1995 Defender 90
There should be a sticker, small white on mine, located on the outside of your ecu, on it hand written by the tech who installed, two numbers. one of the numbers is the prom number and a dealer could tell you if yours has been upgraded or not.... (good info to know about your rover but if its not broke maybe don't fix...)
ecu
Rebuilt air flow meters MAF only $160 Antonios Misc. Chit-Chat 9 March 9th, 2006 10:06 PM
What do I need to know about rebuilt cylinder heads (non-LR) loykd Defender Technical Discussions 2 October 18th, 2004 10:36 PM
Rebuilt ZF auto Transmission mudrover For Sale - Parts 6 September 28th, 2004 02:45 PM
Rebuilt LT230 Transfer case Bill Jansz For Sale - Parts 0 March 9th, 2004 07:00 AM
Eproms, ECUs, need data Doug Defender Technical Discussions 2 February 10th, 2004 08:24 PM
