Rebuilding Tdi Turbo - Defender Source
Old May 4th, 2015, 01:29 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Any recommendations re who to send one to?
Old May 4th, 2015, 01:47 PM
Everyone I've talked to said the cost-benefit isn't worth a rebuild...you'll be $500-ish into a rebuild, and new ones are maybe $700-750.
That said, locally United Diesel in Alexandria could certainly do it (talk to Russell or Scott). Alternatively, Tom (tjfslaughter) has a place in NJ I believe, or there's Tri-State Turbo (info@tristateturbo.com), or Jeff @ Turbo Auto (turboaut@bellsouth.net, 615 383-6242). I actually heard good things about Turbo Auto and was going to give Jeff a try when I was "in the market" for a possible rebuild. But going local at United Diesel is probably not a bad idea.
However - have you pulled the specific Garrett turbo# from your unit? You may want to price it out just based on that model number and see what you come up with.
Old May 4th, 2015, 01:53 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
did 2 for me 300-350 range
he has a core of mine if you don't want to be layed up
Old May 4th, 2015, 01:55 PM
Best price you'll find on a VNT is around $1500. Rebuild always makes sense.
Mark Kellgren
KM4BOR
Old May 4th, 2015, 02:07 PM
New Garrett T250-04 was around $750 last I checked....
Old May 4th, 2015, 02:41 PM
Lav, please share the logic how rebuilding is not worth it @ 200 bucks less than new?
Carlos Z has posted the guy he has used locally. I think Clay will get away with just a renewal of the bearings. I don't think his has any damage to the impellers. But, don't recall looking that closely and will leave that determination up to the pros.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old May 4th, 2015, 02:47 PM
New housing, new warranty, new everything...plus you've got to ship the old unit into them, transit time both ways, turnaround time for rebuild, etc. With 'new' you then "know" exactly what the internals are (versus are the "rebuild" components some Chinese knockoff parts? Will they fail within a short amount of time? etc.). Lots of unknowns with a rebuild, though probably not as dire as I make it. My point is, sometimes maybe a hundred or couple hundred bucks is worth piece of mind...particularly when we're talking about an $8-10K engine swap.
That said, if Jeff @ Turbo Auto can rebuild for $300-350, my money would be on him (as I pointed out above initially).
Lastly, depending on condition, I'm sure you could sell the old one for a few bucks to further lessen the overall difference. Sell the old one for $100-150, and maybe you're talking about a breakeven on rebuild versus new.
It's all ball bearings these days ....
Old May 4th, 2015, 02:49 PM
Just like using a Brit Parts clutch instead of a factory clutch. It may work but if it fails it isn't worth the savings.
Old May 4th, 2015, 02:50 PM
Ask me how I know about that one too! But yes, bingo - what Dave said .
Old May 4th, 2015, 03:02 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
https://www.tristateturbo.com/
I like these guys. You might be able to have them build it as a VNT.
Old May 4th, 2015, 03:23 PM
Any decent rebuilder will warranty for at least a year.
Mark Kellgren
KM4BOR
Old May 4th, 2015, 03:25 PM
I'm working on the assumption the rebuilder isn't going to use cheap chinese parts. Downtime isn't an issue here and I don't think shipping is either for something as small as a turbo cartridge. $200 is still $200. I'll be curious to see how the rebuild shakes out.
Present:
1987 RRC- "Chewy 2"
Past:
Old May 4th, 2015, 03:44 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
It's all ball bearings nowadays ....
I'm gonna need a pair of pliers...
I was under the impression you just run these blenders till they blow...no?
Clay, you building a racecar or somethin'?
Rent my
Old May 4th, 2015, 03:48 PM
tjfslaughter
thomas
Burbon
The guy I linked above uses Genuine Garrett parts and bench is also bench tested.
Old May 4th, 2015, 03:50 PM
Unfortunately, except for the compressor housing and pressure actuator, the VNT is pretty much completely different from a standard turbo.
Old May 4th, 2015, 03:57 PM
1of40's Avatar
1of40
1of40
Race Tractor. No, just listening to advice along the way and trying to weight decisions rightly or wrongly.
Old May 4th, 2015, 03:59 PM
If it is guaranteed genuine Garrett parts built by a certified repair facility I wouldn't fear a rebuild. There would be no difference between that and a new genuine Garrett turbo other than that new turbo smell and the guarantee on the box.
Old May 4th, 2015, 04:33 PM
Jeff at Turbo Auto is great. I posted in the 2.8 compatible thread that he can get the genuine vnt catridge.
Mark Kellgren
KM4BOR
Old June 2nd, 2015, 07:31 AM
1of40's Avatar
1of40
1of40
Posting up a little dose of reality. Dropped off my 20 something ERR4893 with United Diesel in Alexandria. After inspection they want $700 to do the rebuild. I case you wondering what this includes I assume everything a 20 something part would likely need. The phone call was polite but not very long.
Old June 2nd, 2015, 08:21 AM
All they are gonna do is take it apart and put in a new CHRA. Replace the clamps and snap ring and bead blast the housings.
CHRA part number: 443854-0110 Turbo model T250-04.
Quick google search turns up:
Garrett T250-04 CHRA Cartridge 443854-0110
I have sent an inquiry to the USA HQ to see if they have or can get these.
Turbo Diesel or Diesel Turbo? Paul K Misc. Chit-Chat 11 April 11th, 2013 11:59 PM
Rebuilding a caliper Andrew Vick Defender Technical Discussions 11 February 17th, 2008 03:44 PM
Rebuilding LT77 Trans... Stmpede Defender Technical Discussions 11 March 21st, 2007 08:24 AM
Rebuilding a v8 engine - how to fix liner problems robisonservice Defender Technical Discussions 10 August 19th, 2006 10:18 PM
Caliper rebuilding, suggested or to be avoided? Hans Defender Technical Discussions 10 September 3rd, 2005 07:10 PM
