Rebuilding 3.5 V8 Power steering pump - Defender Source
Old December 7th, 2015, 04:22 PM
toad's Avatar
toad
Cutter
the hydraulic pump on my truck is making quite a racket, sounds like the bearing is going. How involved is rebuilding one of these, assuming the parts are available? I don't see a grease fitting or anything to lube it.
Old December 7th, 2015, 06:08 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
I can't answer the rebuild question but I picked a new pump up last for $160 shipped on eBay. Might be worth a look.
If you do the rebuild please do a write up.
Old December 7th, 2015, 08:55 PM
toad's Avatar
toad
Cutter
Well it appears my pump is of course the NLA cast style, I'd imagine I can retrofit the newer style but I'll probably need brackets etc. In case anyone has one of these laying around let me know 610020 STEERING PUMP PAS | shop | www.lrseries.com
On the plus side if it gives out it will be like driving my series again...
Old December 7th, 2015, 09:34 PM
I'd try fitting QVB101110 before I'd try rebuilding one. Your pump isn't NLA btw but its 480 euro which is nuts.
Old December 7th, 2015, 10:05 PM
toad's Avatar
toad
Cutter
Ha yeah I think I can get a full 3.5 for that. I'm overdue for a stay at Overland Engineering, I'll let Matt have all the fun.
rebuild, v8
Steering box rebuilding TDI Guy Defender Technical Discussions 41 September 2nd, 2015 05:07 PM
95 d 90 power steering pump Needed Scott 9835 Wanted 2 November 28th, 2006 12:56 AM
Power steering pump johnnyg15 Wanted 0 August 16th, 2006 05:32 PM
D90 Power steering PUMP WhiteD90 Wanted 1 February 1st, 2005 12:09 PM
Vendor for Power Steering Pump Pulley wheel ? norros Defender Technical Discussions 0 January 19th, 2005 04:12 PM
