Rebuilding 24 spline axles, ABS ring needed? - Defender Source
Old August 30th, 2015, 05:32 PM
bossman429's Avatar
bossman429
Adrian
1988 90
So a couple quick questions:
I got a set of D1 axle assemblies I plan on using in my series coil build. I won't be running ABS. Any reason why i should put the ABS rings back inside the rear rotor hats? Other than i guess having some open holes if don't?
Old August 30th, 2015, 05:34 PM
I did not replace the reluctor rings on my rear 24 spline swap and have suffered no ill effects. The rear stubs/hubs were taken from a D1 axle as well. The new rotors have been fine without the rings.
Old August 30th, 2015, 05:43 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Thanks. That's was I figured but just wanted to make sure. I couldn't see there being an issue
Prob going to keep the dust shields off as well. All they are good for is trapping mud rocks and sticks from my experience
Old August 30th, 2015, 08:46 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by bossman429 View Post
Thanks. That's was I figured but just wanted to make sure. I couldn't see there being an issue Prob going to keep the dust shields off as well. All they are good for is trapping mud rocks and sticks from my experience
I kept both off when I built mine up.
axle, rebuild
Abs vs non-abs swivel pins jafir Defender Technical Discussions 6 October 14th, 2014 08:24 PM
ABS CVs fit in non ABS car? sflash868 Defender Technical Discussions 2 July 21st, 2014 06:55 AM
36 spline versus 48 spline steering wheels transientmechanic Defender Technical Discussions 31 November 13th, 2013 09:57 PM
GBR HD non ABS rear axles $350 RoverDude For Sale - Parts 5 March 7th, 2013 10:39 PM
New jate ring- recovery ring for frame Tyler Wirken For Sale - Parts 0 November 1st, 2011 10:16 PM
