Rebuild screeches to a halt--WTF!!! Free beer! - Defender Source
Old April 13th, 2010, 02:03 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Angry Rebuild screeches to a halt--WTF!!! Free beer!
Quick background. Old 4.6 had a porous block. Swapped to another used, pressure tested block. Same crank (ground a second time, .20/.20), new bearings, timing chain, same old everything else. Built it in the garage, just dropped it and tranny/transfer back into the truck and assembled 90% of it. Went to put on the pulleys and belts and the first thing I noticed is that the BELT TENSIONER CAN'T ALIGN WITH THE CRANKSHAFT PULLEY--it can't come out far enough. That can't be right. Water pump pulley doesn't align with the crankshaft pulley, either. Aren't the timing marks directly under the timing indicator that bolts to the front? Mine isn't--the indicator barely reaches the flat area and doesn't come close to the marks. The Alternator, however, has it's pulley aligned with the crankshaft pulley which leads me believe that the front cover doesn't stick out far enough which doesn't make sense.
The front of the crankshaft is only slightly recessed from the flange on the pulley (enough to cause tension/friction when you put on the crankshaft bolt)--I have a spacer on the crankshaft since I am using a 4.6 crankshaft but old style timing cover (distributor)--but I am reusing the same one.
I have no fucking clue what is going on. Yeah, I am tired, grouchy and pissed, but I still tried to figure this out and am stumped. I'm feeling a bit stressed right now--I know my wife and friends would like to see me more but I really don't function well when my D90 is sick and it is almost wheeling season. Help if you can--I am missing something and the first person to let me know what boneheaded mistake I am making I will send a selection of my absolute favorite IPA Beers to. I'm a hop head, for sure.
ID:	26580   Click image for larger version
Old April 13th, 2010, 02:26 AM
CDeWan
Clay DeWan
5.3L beastie
The only thing I can think of is that your either your crank key is keeping the spacer from dropping all the way in, thus causing your pulley(balancer) to not tighten all the way. so just to be sure or your oil pump shaft is preventing the distributor drive gear to slip onto the crank all the way.
1 slip distributor/oil pump drive gear on crank (hopeully as mentioned above you did not try to install the oil pump shaft as it may be preventing the drive gear from seating on the crank
2 put in spacer,
3 tighten down balancer
4 install pump gears and pack pack pack that mofo with grease so that it gets the oil pressure up quickly
5 install the distibutor drive gear.
pull
Old April 13th, 2010, 03:42 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I thought (from dim and distant memory) that the oil pump and distributor ran off of the cam shaft drive?
Either way I'd pull the front cover and check everything with a clear head, something isn't right and trying to force it will end in broken gear.
Try checking the pulley seats correctly on the crank without the front cover on, take some measurements to the pulleys from the front of the block then you can see if the alignment is right.
Mike Hammond
Old April 13th, 2010, 04:15 AM
CDeWan
Clay DeWan
5.3L beastie
[QUOTE=CDeWan;215979] Possibly your your crank key is keeping the spacer from dropping all the way in, thus causing your pulley(balancer) to not tighten/seat all the way.
Or your oil pump shaft is preventing the distributor drive gear/oil pump gear from slipping onto the crank all the way.
the oil pump shaft as it may be preventing the drive gear from seating on the crank)
2 put on spacer,
3 put on balancer
Old April 13th, 2010, 06:32 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
put the pulley on first...THEN the spacer........
Matt Browne
Old April 13th, 2010, 09:25 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Matt, shoot me your address! That is what I get for working 14 hours on the truck and skipping meals. Total monster brain fart. The second you said that, it totally made sense. PM me--thanks!
Old April 13th, 2010, 10:23 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Originally Posted by Davis View Post
....I really don't function well when my D90 is sick and it is almost wheeling season.
Haha, too funny. Glad you figured it out.
MUDSUX
Old April 13th, 2010, 10:43 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Send him root beer. The mudge prefers it to beer.
Old April 13th, 2010, 12:26 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
hey, no worries mate. Wasn't in it for the beer.
Matt Browne
Old April 13th, 2010, 01:24 PM
Thread winner!
Old April 13th, 2010, 06:00 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
If it was me, I would of put in a new water pump, I'm just saying....
Robert Deniro
Old April 13th, 2010, 08:36 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
Originally Posted by Ren Ching View Post
Thread winner!
yup....can have a (root) beer anyday! It's all about the glory on The D-90 Source!
Matt Browne
rebuild
1988 RR for parts (free as in beer) dieselrover For Sale - Parts 4 April 24th, 2007 12:35 AM
FREE D90 Aluminum Roof Panel Roadsiderob For Sale - Parts 13 February 15th, 2006 11:38 PM
Music and Beer gtg067i Misc. Chit-Chat 8 February 13th, 2006 03:46 PM
8274 Brake rebuild Red90 Defender Technical Discussions 4 October 4th, 2005 10:52 AM
