rebuild or replace my LT85? - Defender Source
Old February 12th, 2015, 09:41 PM
Brentflyfish's Avatar
Brentflyfish
Brent McDonald
1988 LHD 110 SW
Hello All,
I am a new member to the 110 club and recently imported a pretty decent 1988 LHD 110 with AC. I am enjoying the truck but have an important question about the transmission. My truck has an LT85 with the expected issue of lots of bearing noise. It also has a thow-out bearing issue as the transmission does not fully disengage from the engine. I to fix this issue and at the same time rebuild the transmission. I have a few questions for all of the experts here on the page.
1. Is it worth rebuilding the LT85 given the challenges of finding parts and the history of bearing failure or should I swap it out for an R380?
2. The second question is this - I intend to trade out my 3.5V8 for either a 4.2, 4.6 or possibly a 300TDI at some point. is a conversion to the R380 okay for this?
3. Lastly, if I were to keep the LT85, any suggestion where to have it rebuilt? I live in Nashville Tn.
Thanks all!
ID:	113640   Click image for larger version
ID:	113642   Click image for larger version
Old February 12th, 2015, 09:55 PM
RBBailey
RBBailey
1965 IIa
Beautiful truck! I'm getting more and more interested in doing away with the white top -- due to the awesomeness of trucks like yours.
I can't really ad much, since although my transmission is not having issues, I have all the same questions you have.
I also have an '88 with the AC... but it is dead. At some point it must have caused enough condensation in the bulkhead that it rotted it away and the AC unit was pulled and my whole dash is messed up, along with a home built heater box under the bonnet.
Did your truck come from Dubai?
Old February 12th, 2015, 10:53 PM
grnrvrs's Avatar
grnrvrs
Paul
88
1. Check/adjust the clutch pedal.
2. Check the transmission fluid.
IF you are thinking about rebuilding yours or sourcing a rebuilt R380, check with Rob D in ABQ. He rebuilt my LT95 a few years ago. I am extremely satisfied.
1970 SIIA 88, Sold
Old February 12th, 2015, 11:26 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
^^^^^ Roadsiderob on the forum here. I have one of his transmissions in my truck - love it.
Old February 14th, 2015, 11:59 AM
Brentflyfish
Brent McDonald
1988 LHD 110 SW
Thanks all. I think I am going to do a conversion to an R380. Will likely link it to a 4.2 or 300Tdi at some point.
Thanks for the complements as well. I like the white roofs though as they look classic to me but don't pair as well to metallic paint IMO. I think I will likely strip the inside and line it with truck bed liner material. Anyone done that and how did it turn out? Does it stick to dynomat?
ac, rebuild
Transfer case replace or rebuild? LandWorks Defender Technical Discussions 2 July 6th, 2012 05:57 PM
What fluid for a lt85 tranny draaronr Defender Technical Discussions 19 May 10th, 2012 01:20 PM
Rebuild or replace? dnp Defender Technical Discussions 4 February 4th, 2009 02:19 PM
Engine rebuild/replace advise needed. cgalpin Defender Technical Discussions 104 May 24th, 2007 09:14 AM
serial # differences from lt85 and lt77 draaronr Defender Technical Discussions 1 August 30th, 2004 11:56 AM
