rebuild Calipers - Defender Source
Old July 27th, 2010, 08:57 AM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
rebuild Calipers
My front pads are wearing all erratic. one pad was 75% on the inside right and the outside left was gone. the inside left I could not get the clappers to compress enough for the new pad so I had to put the 25% worn pad back in. So I am thinking I need to rebuild the Calipers. I have Lockheed's. I looked at RDS and he has a rebuild kit for$125. DAP has refurbished for 159 + core. or new for 225. I was thinking If I am getting OME Lockheed's from DAP with the refab I would go that way. Does anyone have any direction for me?
Old July 27th, 2010, 09:17 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
You probably did, but, did you have the cap off the reservoir?
Old July 27th, 2010, 11:07 AM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
yes, and bled them.
Old July 27th, 2010, 11:42 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Erratic wear is almost always cause for a rebuild, they may not be floating calipers but if all 4 pistons are moving ok the pressure should be nice and even.
At the prices given, I'd probably go with just getting an already rebuilt or new caliper. I remember snagging a rebuild kit with pistons for $60 or so about 5 years ago, which made rebuilding yourself a good deal, but since the prices are now double..... there's no point to it.
-Hans
My oil line fix
My 100k stopped odometer fix
Old July 30th, 2010, 09:10 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Yeah, getting new ones is always the best option, to properly rebuild the existing ones you need a hone, and might even need to split them and that's honestly just too much headache to save $40 the 2nd time (since a hone is about $20-30). It's also a good time to put a coat of caliper paint on to keep the corrosion at a minimum.
rebuild
8274 Brake rebuild Red90 Defender Technical Discussions 4 October 4th, 2005 10:52 AM
Ideas for CVC's "banana flambe" rebuild evilfij Misc. Chit-Chat 24 September 23rd, 2005 01:10 PM
where to find rebuild manual for 4.0L? Chris Cox Defender Technical Discussions 0 January 27th, 2004 09:36 PM
Front Brake Calipers 1of40 Defender Technical Discussions 7 December 30th, 2003 12:46 PM
» Defender Registry
Series III
kraison
Pancho
LPP
Add your Defender
