Rear wiper park switch - Defender Source
Old September 21st, 2016, 05:57 PM
Sanbornc
Christopher Sanborn
1990 Defender 110
I'm installing a MUD center console in my 1990 110. With this installation I have to remove the switch that controls the rear wiper. My plan is to install a Carling Contura xiv switch to control the wiper (off-on-(on)). My concern is the park function of the rear wiper. Is this function within the switch or is the circuit elsewhere?
Basically, can I just simply replace the switch and have the wiper still function.
Old September 21st, 2016, 07:14 PM
Wiper wiring requires a switch with a fairly specific design. There is a park circuit that is closed with the switch off and the running circuit that is closed with the switch on. You can't just use a normal switch. The switch must be specially setup for use with a wiper.
Old September 21st, 2016, 07:20 PM
Here: http://www.mudstuff.co.uk/products/e...pe-switch.html
Old September 21st, 2016, 07:33 PM
Sanbornc
Christopher Sanborn
1990 Defender 110
Thanks for the info. This is the switch I bought (different vendor). I if I'm understanding correctly, the park circuit is not is the OEM switch but elsewhere. As long as I wire the switch correctly everything should work. Correct?
Old October 5th, 2016, 07:54 AM
Sanbornc
Christopher Sanborn
1990 Defender 110
John, or anyone else, do you know the part number for the rear wiper switch on Mud? I'm they only have the switch with a green indicator and I'm looking for blue (if available). I have tried to call Carling distributors and they were no help.
Any thoughts?
Old October 5th, 2016, 09:20 AM
Any thoughts?
Carling part# for Wash/Wipe is VRD2GHNB-AAC6U-100:
https://www.seriesdefender.com/switc...pe-switch.html
And here's the wiring diagram if you need it:
Old October 5th, 2016, 09:11 PM
Sanbornc
Christopher Sanborn
1990 Defender 110
[QUOTE=nathanwind;772488]Carling part# for Wash/Wipe is VRD2GHNB-AAC6U-100:
Old September 16th, 2017, 02:17 AM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
Bumping this... question on the wiring:
In Jason's RWW switch diagram - the switch color to number diagram, when it says: "Green link to Pin 5" and "Green link to Pin 3".. does this mean I need to jumper pin 5 and pin 3 together? Or is this a either or condition - since it says "can link to 5" or can link to 3"?
I noticed the RWW, and a couple other switches call for linking the pins. I am a little confused what I should do when they say... "link to pin #".
Thanks!
Old September 16th, 2017, 09:14 AM
Switched power goes to both 3 and 5.
Old September 24th, 2017, 12:45 AM
lithium1330
'97 SW NAS 4.6
I just pulled the factory rear wiper & washer buttons. I have a 1997 D90 NAS.
Aside from the lights+ground, each button only has 2 wires connected.
The Wiper button has one (green) wire and one (green+red) wire.
The Washer button has one (green) wire and one (black+green) wire.
Looking at the Carling wiring diagram from Jason... I am missing one brown+green wire (wiper park) from the factory harness. Did they remove that from certain model year?
Thanks!
switch
Rear Defrost Switch, Rear Wiper Switch, and Rear Wipe/Wash Switch bradfordish For Sale - Parts 5 January 26th, 2014 12:30 PM
Wiper Park issue (only on normal/fast speed) rlynch356 Defender Technical Discussions 10 October 28th, 2009 09:07 AM
wiper motor - park kevorkjan Smaller Projects 6 May 22nd, 2009 11:45 AM
Rear wiper switch wiring? JackW Defender Technical Discussions 4 September 24th, 2007 06:48 AM
What makes the Rear Wiper park? COSteve Defender Technical Discussions 10 March 6th, 2007 04:40 PM
