Rear Wheel Brake Fluid Leak - Defender Source
Old December 13th, 2017, 10:59 AM
FlyersFan76
1987 110 Convertible
As previously mentioned in another thread my '87 110 failed its inspection.
Might have more to do with the other issue than the break issue but alas here I am.
My right rear wheel shows signs of a break fluid leak. It isn't that bad as the truck runs and stops fine. The back of the wheel shows a break fluid spider web but not as bad as I have seen on other vehicles with a fluid leak.
What parts and procedures should I be looking for?
Thank you
2011 Range Rover Sport
1987 Land Rover 110 Cabriolet
1997 Defender 90- AA Yellow #1701- Wrecked
1997 Defender 90- AA Yellow #?- Sold
2000 AM General Hummer- Sold
Old December 13th, 2017, 08:02 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You sure it is the brakes and not the hub seal? If you have drum breaks might just have a leaky cylinder. Also check the integrity of the brake lines. Old lines can be rusting bad enough to cause a leak.
Land Rover 110
Old December 27th, 2017, 01:45 PM
FlyersFan76
Thanks. I haven't laid down to give it a very close look. Hopefully I'll be looking this weekend.
brake, wheel
Blew u-joint in rear, help on 4 bolts removal on brake drum UpnOver Defender Technical Discussions 3 February 2nd, 2012 07:53 PM
Rear disc brake options kellymoe Defender Technical Discussions 44 April 9th, 2008 09:34 AM
Rear Brake Light Bar or Antenna boshea Wanted 3 September 9th, 2005 07:55 PM
New Leak d901560 Defender Technical Discussions 0 May 2nd, 2005 03:21 PM
