rear wheel bearings - Defender Source
Old April 18th, 2015, 08:20 AM
rear wheel bearings
ive got quite a few wheel bearing/hub repairs under my belt by now. i have only had to readjust the bearings a few times.
the rear wheel bearings on my classic are always working themselves loose, both driver and passenger side. it has a detroit locker and two piece axles. i have never heard of people having issues with bearings and the locking differentials . i converted from 10 to 24 spline years ago, i dont recall having the wheel bearings working loose until the detroit a couple of years ago. i used hubs and stubs from a 96 disco
Old April 18th, 2015, 09:55 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
it must be because you went the cheapfuck route
I've never had an issue with ARB differentials
I did have a loose rear caliper yesterday though.
I repacked all the bearings on the Tdi LWB a few months ago and somehow the rear caliper worked loose and was rattling.
When you say they get loose--do you have to retighten the hub nuts?
Did the wheel/hub assembly feel wobbly-is that how you knew?
Rent my
Old April 18th, 2015, 09:59 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Are the hub nuts working loose? Are you folding the lock washer correctly?
Old April 18th, 2015, 10:13 AM
I dont cheap fuck the hubs and brakes. I guess the hub nuts are working loose and yes to the locking washer. I am having to tighten the hub nuts as tight as I am can and they are still getting loose. Im going to replace the bearings and races today TBD....
Old April 18th, 2015, 10:24 AM
If the nuts are physically held in place with the lock washers how can they loosen?
Are you torquing per spec?
Old April 18th, 2015, 10:26 AM
Originally Posted by Red90 View Post
If the nuts are physically held in place with the lock washers how can they loosen? Are you torquing per spec?
Because the tab washer is a stupid design. I thought there was a new design you can upgrade to but maybe I am wrong.
Old April 18th, 2015, 10:34 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
sounds like a race might not be properly seated. If bearings are dis colored then possibly too much wear from either contamination or over tightening, but less likely. Detroits shouldn't matter in the slightest.
Old April 18th, 2015, 10:40 AM
In what way? With the washer folded tight over both nuts how does anything move?
Old April 18th, 2015, 12:14 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
For that nut, see here. http://www.defendersource.com/forum/...ken-30756.html
Old April 18th, 2015, 12:46 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Phillip, I've only ever used the old style 2 nuts/lockwasher system
Tighten the first nut and slightly loosen 2-3 times to seat the bearings.
The last time, I tighten the nut then back it off just slightly, put the lockwasher on, put the 2nd hub nut on and tighten.
Then fold the lockwasher in on the 1st nut, and out on the 2nd nut.
Never had one loosen. /#fingers-crossed-now
Rent my
Old April 18th, 2015, 01:03 PM
thats what i have always done. Ive done probably a dozen over the years and have only had two excluding these cause me trouble.
Old April 18th, 2015, 02:09 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Think I'll check mine after reading this. I have a Detroit and just finished the White Rim Trail @ Canyonlands UT, a 100 miles of some pretty rough but mostly level trail.
Old April 18th, 2015, 06:26 PM
So what exactly is happening? Are you saying the bearings are loose, but the nut have not moved or are you saying the nuts are moving?
Old April 18th, 2015, 06:58 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
The old design is such a old design. I've seen 1970 cars with better designs for wheel bearings
I have RFD100000 on all my solid axle trucks and haven't had a loose bearing yet. Before using RFD100000 they would come loose a lot.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old April 18th, 2015, 07:01 PM
For those that are having bearings come loose, are you replacing the lock washer? I've seen them get worn out allowing the nuts to rotate.
Old April 18th, 2015, 09:57 PM
i replaced the entire hub and bearings, i reused the grease seal. will report back with findings. i hate that fucking lock washer, going to order the new style nut.
on another note when did land rover change the drive flange bolts?
Old April 18th, 2015, 10:15 PM
They are not supposed to be reused.
Old April 19th, 2015, 12:24 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I've reused plenty. And been running Detroits a decade. I basically do what Jeff B. says , I wheel in very rocky Colorado and I don't have loose bearings, so my guess is something else is up...
Old April 19th, 2015, 04:38 AM
You say you did a conversion from 10 spline rrc to 24 spline disco. I recently did the same and found that the disco stubs use a different style of spacer than the rrc. Do you recall swapping in the thin, keyed washer during your conversion? It goes between the outer bearing and the first nut.
Old April 19th, 2015, 08:30 AM
IIRC I reused the washer from the 10spline stub axle.. ilI'll order those when I order wheel seals. The passenger side hub felt "good" so I left it alone. Thanks for mentioning that, I figured I had my bases covered with the stub/hub
wheel
How to: rear wheel bearings?? Spenc1tj Defender Technical Discussions 13 April 10th, 2014 05:52 AM
Rear wheel bearings: "while I'm at it" list? MonLand Defender Technical Discussions 27 October 1st, 2013 07:34 PM
Rear axle noise at 15-20mph+ -> wheel bearings? MonLand Defender Technical Discussions 13 October 1st, 2013 01:10 PM
Wheel Bearings and stub bearings Naplm00 Defender Technical Discussions 9 March 11th, 2011 10:17 PM
wheel bearings and seals Uncle Douglas Defender Technical Discussions 8 August 20th, 2010 08:18 PM
