rear wheel bearings - Page 2 - Defender Source
Old April 19th, 2015, 09:51 AM
Originally Posted by Davis View Post
I've reused plenty.
So have I, but they aren't made to be reused, and I have seen cars come in with loose wheel bearings as a result of this.
Old April 19th, 2015, 10:56 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
interesting I presumed they were reused but I could see worn washers causing seating issues
Old April 19th, 2015, 11:14 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I would be curious at how they became loose---were the tabs so fragile from bending that they flexed back and the nut spun? I definitely haven't reused any that were that weak, and even have a difficult time believing that my reused ones could be that weak. The keyed flat spot has no way to spin and the tab would have to bend way back to allow any slop. From a totally mechanical perspective, and as long as it is still intact and bent against the nut, I don't see any way that they could cause the slop. I would suspect that the slop was created through bearing wear or improper original assembly. That said, I bet most people don't understand the principle of how to bend the tab back onto the nut. It isn't a matter of bending it back--it is also where you bend it back. You bend the tab back against the corner of the nut that, were it to back off, would be the first to hit the nut, not "just" the flat spot on the nut. Most folks don't know that... and I bet the ones that you saw loosen were not bent correctly...
Now if you have seen them fail and the nut slip back, that is an entirely different scenario and of course that would cause it. But otherwise, I just don't see it...
Old April 19th, 2015, 12:29 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
^^ Chris- hit the nail on the head....or the lock washer! ^^
Rent my
Old April 19th, 2015, 01:08 PM
The flat spot can become rounded causing the clock washer to be ineffective. When that happens the nuts will loosen or tighten depending on what side of the vehicle it is on. I have seen this happen.
Old April 19th, 2015, 01:11 PM
Originally Posted by rover4x4 View Post
IIRC I reused the washer from the 10spline stub axle.
Remember: the 10 spline and 24 spline washers are totally different.
http://www.defendersource.com/forum/...tml#post607969
You must get the keyed, thin washer - not the RRC washer.
Old April 19th, 2015, 02:42 PM
I am using the disco washer for sure. I was thinking the big washer against the bearing was thinner based on what youd said. I always replace the locking tab. FWIW my most recent "genuine" locking washers wouldnt fit on the stub axle, the ID was to small.
wheel
How to: rear wheel bearings?? Spenc1tj Defender Technical Discussions 13 April 10th, 2014 05:52 AM
Rear wheel bearings: "while I'm at it" list? MonLand Defender Technical Discussions 27 October 1st, 2013 07:34 PM
Rear axle noise at 15-20mph+ -> wheel bearings? MonLand Defender Technical Discussions 13 October 1st, 2013 01:10 PM
Wheel Bearings and stub bearings Naplm00 Defender Technical Discussions 9 March 11th, 2011 10:17 PM
wheel bearings and seals Uncle Douglas Defender Technical Discussions 8 August 20th, 2010 08:18 PM
