Rear Wheel Bearing Parts - Defender Source
Old March 26th, 2012, 10:13 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
I have been asked by my mechanic to order the parts to replace the rear bearings in my NAS '97 D90 SW. I went to Rovers North but all of the parts seem to be for the front and I can't figure out which parts also work on the rear.
http://www.roversnorth.com/store/c-1...-assembly.aspx
Anyone bored enough to help me round up a parts list (with part numbers) for replacing my rear bearings?
I'd like to replace any optional seals and gaskets while they're in there. Suggestions welcome.
Thanks in advance!!!
Old March 27th, 2012, 12:32 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Front and rear are the same. If you are just doing the bearings then get 2 Timken set #37 for each wheel or you can buy a kit from AB - http://www.roverparts.com/Parts/9002D.cfm
You can reuse your locking nuts and fold over tab washer or get a new nut (p/n RFD100000) which I highly recommend.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old March 27th, 2012, 12:48 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Hans, you're welcome to bring the truck by my house and we can do the bearings in a couple of hours. It's super easy.
Then again, PPR is awesome and I'm sure they could knock it out really quickly, too.
Old March 27th, 2012, 04:58 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
You can get the bearings locally at any auto parts store for about $14 each. Timken SET37, SKF BR37, FAG KIT38 or National A-37.
RTC3511 hub seal. Maybe a lock washer and the gaskets. Trevor at Rovahfarm will send the seals, etc. in a small priority USPS flat rate box so you should have them in a couple days.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 27th, 2012, 10:15 AM
If it were me, I would do rear rotors and pads while I was in there as it is not much more time in labor.
Old March 28th, 2012, 11:56 AM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Gents, Thanks very much for the help! I love this place.
------ Follow up post added March 28th, 2012 09:59 AM ------
Chris, Thanks much for the offer! The dealership is replacing my new rear diff (long story. VERY long story). I am having them do the bearings while they have it apart.
Old March 28th, 2012, 02:16 PM
chris snell
Chris Snell
87 Ex-MOD 110
No worries, Hans. That said, you don't have to pull the hub and bearings to remove the diff so if they want to charge you to do the bearings, the offer still stands.
Old March 28th, 2012, 05:21 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Understood - and, again, thanks for the offer. That's very kind of you.
I've had the back of my track apart twice before -- in my own garage -- for this same $%^&* issue. Now I am out of time and out WAY of patience. When I get it back, I don't want to touch the rear end with a wrench for another 130k miles.
That is to say... not until I take off the Rock Ware trailing arms and replace the upper ball joint.
part, parts, wheel
wheel bearing D90user Defender Technical Discussions 15 April 17th, 2006 09:35 PM
D90 and Series Parts for sale rrubino2 For Sale - Parts 20 January 26th, 2005 05:31 PM
Rear wheel bearing damage potential?? Neo Defender Technical Discussions 8 November 28th, 2004 11:58 AM
Barnett Childress chrisvonc Defender Owners 0 February 29th, 2004 12:47 PM
