Rear wheel bearing damage potential?? - Defender Source
Old November 24th, 2004, 10:23 PM
Neo
Jeffrey Rosbrugh
95 D90 ST #2585
Hi guys, I am looking at making a fairly long trip (for me) in my 1995 D-90 and read somewhere there is potential for rear bearing damage due to lack of oil. If memory serves me correctly, this is due to a supposed "fix" LR tried to prevent the rear seals from leaking, but ends up hypothetically starving the bearings of oil. Is there any real concern here on about a 1000 mile trip? Do I need to do anything to prevent it? Thanks! Happy turkey eatin!
Pain is weakness leaving the body
Old November 24th, 2004, 11:28 PM
Jeff, the rear bearings are packed in grease not oil, as long as the grease is clean then they should be fine. One problem that can happen is the inner axle seal can get damaged when inserting and removing the axle shafts and allows diff oil into the wheel bearings. But when this happens the oil goes all over the breaks. An easy check for the bearings is to jack up the wheel and spin the tire by hand and listen for grinding noise, then check for play in the bearings by trying to shake the tire from top to bottom.
Old November 25th, 2004, 01:58 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Having grease and oil is just fine. I have been running that way for a long time. Even if you blow out the bearings and race, you are looking at $100 a side. Not too bad.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 25th, 2004, 12:21 PM
redrover
Guest
Posts: n/a
Jeff ,I dont know where you read that, but it doesnt make any sense. Like said earlier the bearings are packed in grease. The seal inside the spindle keeps the axle 90 weight gear oil from mixing with the grease in the hub. This seal may get old and allow some oil to mix in with the grease--No Problem. If the seal on the inner side of the hub is bad then you could have dirt and water getting in to the hub bearings. Yes Problem. Or it could allow oil mixed grease to get out and toast your brake disc pad's. SOOOO if your wheel spins free and there are no visible leaks then I wouldnt worry. PS I would pull the wheel hubs and repack the bearings if you have higher miles on the clock and dont see it in your service history. JP
Old November 25th, 2004, 06:43 PM
Neo
Jeffrey Rosbrugh
95 D90 ST #2585
Thanks for all the info guys! What grease do you all recommend, simple wheel bearing grease or anything special? Is re-packing pretty simple? Thanks again!
Old November 25th, 2004, 07:26 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
mobile1 and valvoline both make a nice synthetic grease. That is what I use.
Old November 25th, 2004, 09:50 PM
I like the Mobile one syn grease also, it is pink so it is very easy to tell when it gets dirty.
Old November 28th, 2004, 01:12 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
Another vote fpr the Mobile 1 grease.
Old November 28th, 2004, 11:58 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Having the wheel bearings running in oil is fine. The earlier 90's & 110's didn't have the seals on the shafts and the bearings run in oil. My 110 has 166000 miles under it's belt, I've done nearly 100,000 of those miles and had no trouble with the bearings atall. The problem comes when the hub oil seal fails, water gets into the grease packed bearing and it then destroys itself. Keep the hub oilseal in good condition, that will protect the wheel bearings. I believe the British Army took the seals out of the axles that stop the oil getting to the wheel bearings so that they could run in oil as opposed to grease. Make sure the axle breathers are clear and you'll have very little problem with oil getting past the hub seal.
If only getting my 90 to run properly was so simple.
Mike Hammond
damage, wheel
wheel bearing D90user Defender Technical Discussions 15 April 17th, 2006 09:35 PM
Right Rear damage - Whats the best way to fix hutclose Wanted 2 July 23rd, 2005 03:58 AM
Rear Spare Wheel Carrier DiscoDino Defender Technical Discussions 5 May 21st, 2005 04:35 AM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
