rear vibration on 110 - Defender Source
Old June 3rd, 2013, 12:02 PM
Under load I've had a rear vibration for a while now and want to address it. My 110 has a RTE 3" lift w cranked fronts and a double cardon GBR shaft, but stock trailing arms and shaft in rear. Does anybody with a 3" lifted 110 have a double cardon rear shaft to manage vibration, or would cranked trailing arms likely solve my issue?
Mark Kellgren
KM4BOR
Old June 3rd, 2013, 12:34 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
You shouldn't need a double cardon in the rear as you have plenty of length. I was running 5" of lift with no driveshaft changes. You can change you pinion angle slightly with some adjustable trailing arms (RTE and a few others), or maybe check your U joint - which sounds like the issue.
Semper Fi!
Old June 3rd, 2013, 12:35 PM
Mark, I don't think that cranking the trailing arms inherently does anything to affect driveline geometry. The crank in the arm affects how much travel is left in the frame bushings for droop.
I believe that for driveline geometry what matters is how long the center-to-center length of the arm is. More length = less pinion angle.
I'm not entirely sure that changing the rear pinion angle would solve the vibration problem, however...
Old June 3rd, 2013, 12:44 PM
Pinion angle is off due to lift. Longer springs and stock trailing arms force front of pinion to lft up. The RTE arms come with spacers to lengthen the geometry and correct the angle.
Old June 3rd, 2013, 12:50 PM
so rte arms should fix prob doug? no new driveshaft needed?
Mark Kellgren
KM4BOR
Old June 3rd, 2013, 12:55 PM
Yes. That shaft is so long I don't see you being in double cardon territory.
Old June 3rd, 2013, 01:00 PM
you need picture two, you probably have four. Because of the ball joint on top of the diff, as you push down the diff with longer springs the short stock arms force the pinion angle @ the front to lift up. Doesn't take much to get a vibration. Lift/longer spring results seem to vary widely from truck to truck. What causes a vibration on one doesn't on another. My 110 had no vibration but ate u joints despite frequent synthetic greasing. I had OME 2755's and a 1 inch spacer in the rear.
Old June 3rd, 2013, 01:23 PM
How old are the U-joints? It might be worth pulling the rear shaft to inspect /replace them, and go for a test drive without it to make sure that is where the vibe is coming from.
-Jeff
I check ujoints for play everytime Im under vehicle, but will check again
Mark Kellgren
KM4BOR
Old June 3rd, 2013, 01:30 PM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
Maybe pull the driveshaft off and have it rebalanced. My Tom Woods was out of balance when I first got it. Chased a vibration for six months until it was suggested to me to get it balanced. Did the trick.
Old June 3rd, 2013, 01:41 PM
That WAS plan A, but I don't want to throw money at the problem without a consensus.
Mark Kellgren
KM4BOR
Old June 3rd, 2013, 01:53 PM
The pinion should be parrellel to the output on the t case. RTE links fix this with spacers
Old June 5th, 2013, 08:27 AM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
Where does the A-arm extension fall into in all of this?
Old June 5th, 2013, 08:52 AM
A arm would be the pivot point that would change the pinion angle as the trailing arms are shortened or legthened.
Mark Kellgren
KM4BOR
Old June 5th, 2013, 09:36 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
I bought some Tom Woods DC shafts for my D1 a few years back and brand new out of the box they had a little low speed vibe (tough to tell high speed with TDI, 5in springs and 36in swampers) but then I bought one for my D2 a couple months ago and it has been smooth as silk.
$200,000 blr 130!!!!!!!!!! rijosho The Flea Market 39 July 25th, 2012 09:58 PM
Feeler: 110 SW rear body conversion parts evilfij For Sale - Parts 0 June 15th, 2012 02:50 PM
110 SW rear door: color/hinge MUDSUX Defender Technical Discussions 6 January 3rd, 2011 02:07 PM
NAS 110 Rear Bumper Reefminis Wanted 3 October 2nd, 2006 04:54 PM
110 3door rear body forsale headdamage For Sale - Parts 4 August 4th, 2005 03:19 PM
