Rear tub restoration question - Defender Source
Old September 4th, 2006, 07:17 PM
Hoosier's Avatar
Chris Hinkle
More than I need
I have a defender tub from the east coast. There was bubblng on the rails (capping), so I drilled out the rivets and pulled it off the tub. I have replacement galvanized rails, but it isn't really necessary here in the south. If I wanted to paint the rails, should I buy ungalvanized pieces? Should I paint them separately and then put them back together or put them back together and then paint? For those of you who have galvanized rails, did you also put galvanized capping on the tailgate and doors? Thanks.
Old September 5th, 2006, 07:29 AM
TDI Guy's Avatar
2015 LR4
Chris, I would just paint the galv capping. It will never rust and bleed through... YOu have to clean it first with a special cleaner then epoxy prim it and paint it. What color are you doing? IF the tub needs it, do both..
Legend in My Own Mind.
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts For Sale - Parts 5 May 20th, 2006 08:19 PM
D-90 Rear Tub Needed ember Wanted 12 March 10th, 2005 04:08 PM
NAS rear tub crobinson Wanted 0 January 28th, 2005 12:18 AM
body capping on rear tub WhiteD90 Defender Technical Discussions 5 October 6th, 2004 05:10 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 10:21 AM
