Rear Tub Questions - Defender Source
Old November 26th, 2011, 03:19 PM
Hinckley423's Avatar
Hinckley423
Charles Joerss
1995 D-90 #2812
Rear Tub Questions
On my 95 ST I had to cut one of the bolts that holds the rear bench seat bracket in place. The bracket was on the drivers side and is was the rear seat rests on when it is not folded forward. When cutting it, I scratched up the side of the tub a bit and I want to fix it primarily to prevent rust. Does anyone have any advice regarding touching the area up? My skills are fairly limited so I am strongly considering taking it to a body shop to have it properly painted. I want to put the bench back in only I've cleaned up under the rubber mat. Any opinions as to how I should go abou replacing the hardware- its pretty rusted. Should I go to the local hardware store?
Also, to protect the rear tub I have a rubber matt. I find that dirt and water get trapped under it. Does anyone have a better alternative? I'm leaning away from having it Rhino-lined. I was thinking about having the local canvas guy make a two piece matt that I can remove without having to take out the bench and all the hardware.
Any advice or insight would be appreciated.
Thank you,
Charles
Old November 26th, 2011, 03:37 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Tub is aluminum - no rust. Touch up paint available through multiple online sources. Soaking rusted bolts with Kroll works well, but sometimes cutting is required. Rhinolining is an option, but it will cover everything semi-permanently
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old November 26th, 2011, 04:11 PM
Hinckley423
Charles Joerss
1995 D-90 #2812
Thank you. So if I don't touch up the scratches the only issue would be the appearance. It wont affect anything else?
Old November 27th, 2011, 10:29 AM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Charles,
I had a local paint shop make me up a couple of cans of spray paint. Just give them the LR paint code. Do a search to get the factory code for blue. I ended up touching up a number of places inside the truck particulary the floorboards.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Defender Rear Tub Panel, aluminum fuel tank cradle pacificwildfire Wanted 2 October 12th, 2011 06:22 AM
110 5 door rear tub Tyler Wirken For Sale - Parts 0 January 19th, 2010 09:59 PM
Tub rear lower hold down metal strip thingy dave_lucas Wanted 9 July 25th, 2009 10:31 PM
Genuine Rear Tub Liner fleabus Defender Technical Discussions 5 July 17th, 2006 02:50 PM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
