Rear trailing arm instalation - Defender Source
Old August 31st, 2012, 01:18 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Are there any tricks to swapping the trailing arms? I picked up some new Rockware ones and I am going to tackle the job tomorrow. Any advice is appreciated
Jason
Old August 31st, 2012, 01:29 PM
do them one at a time with the car on the ground
Jason
Old August 31st, 2012, 02:22 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Support the frame with jackstands and do one side at a time. Make sure you have a prybar or spud wrench handy.
-Jeff
I needed a prybar and a spud wrench! like others said though, do one side at a time and have a little patience. I also spread the ears on my axle tube a little to allow the bushings to slide by a little easier
Old August 31st, 2012, 02:30 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Thanks for the advice. The Rockware ones are 1/4" shorter so should I pull the bolts in the second one or is there enough play to get the first one in there?
Old August 31st, 2012, 02:38 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Ratchet strap is what we ended up using to help close the distance a little.
Old August 31st, 2012, 02:41 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Use a drift not your finger to line up the hole at the axle end.
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old August 31st, 2012, 03:26 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
This.
Using chucks for the rear tires isn't a bad idea either - but you'll need to move the wheel forward just a hair to get the shorter arms installed.
Old August 31st, 2012, 03:38 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
I have straps and comealongs that I can use to get the axle pulled into place but won't that put a bind on the other one, or do you just have to beat the bolt out?
Old August 31st, 2012, 05:07 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I lifted my truck when I did this, just to take some pressure off the springs and propped the axle in order to take the wheels off, much easier like that. Soak everything 24h before. It's good to put new nyloc nuts, I think they're m16.
- Charles Eames
Old August 31st, 2012, 06:33 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
That's how I did mine. The job was very easy with the truck lifted. You can raise/lower the axle as necessary to align things.
I would also use some anti-sieze on the threads since these parts are in the splash zone.
Early Rear Door Limit Arm 61rover Wanted 6 May 25th, 2010 10:45 PM
Rear Door limit Arm 61rover Defender Technical Discussions 0 May 7th, 2010 03:35 PM
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
For Sale: Mantec Steering Guard, NSO Rear Shock Mount, Hinged Radius Arm Doogs For Sale - Parts 8 January 26th, 2005 11:28 AM
rear roll cage, rear seat, soft top surfd90 Wanted 0 January 12th, 2005 02:59 PM
