Rear Top window on D-90 fiberglass top - Defender Source
Old November 7th, 2006, 09:01 AM
ttrover's Avatar
ttrover
Thomas Taylor
1997/ Defender 90
Has anyone put back a top peek window in the fiberglass top for a D90 '97. I am sure some man handling is required but do not want to wreck anything. Any tips or Ideas. What tools will help.
ttrover
Old November 7th, 2006, 09:33 AM
themaxx's Avatar
themaxx
Ade
94 ST
ttrover
I am assuming you mean the Alpine window...
http://www.defendersource.com/forum/...=alpine+window
Old November 7th, 2006, 10:02 AM
It SUCKS!
You need a lot of soap and water, and it still takes force and finesse. Get whatever tool is required to help run the welting strip into the channel. I used a ball point pen, but that kinda sucked.
Old November 7th, 2006, 10:11 AM
themaxx's Avatar
themaxx
Ade
94 ST
Are there any preventative measures that can be taken to prevent this from happening?
Old November 8th, 2006, 09:37 PM
bjenk
Brian Jenkinson
1994 D90
get a little cotton cord that fits in the channel where the window goes and insert the cord in the channel. Get a corner of the window started and then while pressing the window (gentle now!!) against the molding pull the cord. Use warm water and soap in conjuction (molding needs to be warm)
I hope this makes it a little easier.
brian
Old November 9th, 2006, 08:33 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
If the gasket is out I would put in a bucket of hot water to make it more pliable.
It should make it a little easier, but still a pain.......
Old November 9th, 2006, 09:49 AM
Grover's Avatar
Grover
Question
brian
I am about to replace my windshield gasket. Do you recommend the same method, i.e. using a cotton string to assist inserting the gasket? Or should I just go to an autoglass company to have it installed...
Cheers...
Old November 9th, 2006, 09:57 AM
btate
Bryan Tate
d90
Grover,
I have had an auto body shop crack two of windshields when they were painting my truck
(they have replaced alot of glass) so they had a glass shop cut and replace. He made it look easy.
They both use a rope/cord to pull the seal in place.
Moral of the story.....if you do it, I bet you will crack it.
Bryan
90, d-90, fiber, fiberglass, fiberglass top, glass, window
Fiberglass hard Top Disco_Stu For Sale - Parts 29 January 12th, 2009 11:41 AM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
rear roll cage, rear seat, soft top surfd90 Wanted 0 January 12th, 2005 02:59 PM
Fiberglass Hard Top, Cheap wookied110 For Sale - Parts 4 April 3rd, 2004 04:04 PM
