Rear Suspension Question - Defender Source
Old January 30th, 2004, 05:06 PM
dnewman9's Avatar
dnewman9
Dennis Newman
*SOLD*Conniston 97 NAS 90
I have found on my truck that at highway speeds if I abruptly let off the gas the truck torques pretty good to the right? To the point i have to counter steer? It is almost as though the rear end is pivoting?
I have looked underneath and everything looks solid, the bushings look new on the front of the lower control arms and I can not see any obvious problem.
The only thing I thought may be kind of strange is that the front bushing on the lower links are not tightened up enough to squeeze the rubber bushings at all. In fact there is maybe an 1/8 inch gap between the big rubber washer and the bushing? I am used to my early Bronco's where you slightly compress the bushings.
I would think that if it were a problem with the upper link the issue would not be so pronounced from side to side.
Any one suggest anything I could look at?
Dennis
Old January 30th, 2004, 08:15 PM
Mine does the same on occasion. I'll have to check my bushings in the AM and see if they look like yours. Although I think mine is more related to lift, tire size, and tire inflation.
Old January 30th, 2004, 09:19 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Dennis, replace those bushings and retorque the links. THere is prob. some slop in the back right now causing that problem.
Legend in My Own Mind.
Old February 1st, 2004, 06:31 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Make sure you replace both sides at the same time.
I had 1 rubber bush break up and there was a bit of torque steer. I foolishly replaced only the one that broke and the resultant torque steer with 1 new & 1 old bush was very scary, far worse than 1 old & 1 broken bush
Mike Hammond
Rear Suspension Buckon37s For Sale - Parts 5 October 10th, 2005 10:58 AM
question about rear ladder fitting my ride chirider Defender Technical Discussions 1 December 7th, 2004 11:20 AM
suspension question - Scorpion asator Defender Technical Discussions 25 October 10th, 2004 12:24 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
