Rear suspension a-frame interchangeability Disco ~ 90 - Defender Source
Old September 16th, 2009, 09:42 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Would a Discovery I (94 99) rear suspension A-frame, frame mounts and ball joint fit a D90?
Old September 16th, 2009, 10:28 PM
it should
Old September 17th, 2009, 11:07 AM
Dave I believe the frame mounts are weld on for a disco, and if so, you'd need to get defender frame mounts (or have the disco ones cut off and weld onto your frame - but I have no idea what they look like).
hth
charles
Old September 17th, 2009, 11:28 AM
the a arm is the same. the mounts are just attached to the frame differently for some reason
hth
charles
Old September 17th, 2009, 11:32 AM
Disco's do not have the triangle pieces. Look for a wanted post by badgerman a few months ago to see what I am talking about.
Old September 17th, 2009, 11:49 AM
Right, on a disco that piece or its functional equivalent is welded to the chassis. But the ARMS are the same.
Old September 17th, 2009, 12:10 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Thanks guys,
So the ball joint will work as well?
Old September 17th, 2009, 02:03 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Yup, it should work fine.
Keith
Big, Red and ... aaa Red..
Old September 17th, 2009, 07:54 PM
rovertrader's Avatar
rovertrader
Dale
Be aware there are different ball joints as well- a trick George taught me years ago- some are rebuildable, while others are not. It becomes a biggie when time to service same- you won't have to remove it.
Old September 17th, 2009, 08:07 PM
Dale, how do you tell if it's rebuildable? The ones I have have two bolts and it looks like a press fit into the piece the a-arms bolt to. Mine are both in nice and snug so I haven't tried to press them out, but I'm wondering if they are rebuildable or need replacing.
Old September 17th, 2009, 09:24 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I have a rebuildable on my truck, greaseable too. They're ...Okay..
Keith
Old September 18th, 2009, 04:59 AM
rovertrader
Dale
But Keith- you have heated seats too :-)
The rebuildable ones have additional bolts and as Keith said, are greaseable
It's no biggie, I just hate changing them- pain job. No performance issue, just ease of service.
Old September 18th, 2009, 09:09 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I can say from personal experience that the A-Arms and ball joint parts are identical between a 95 disco and 95 D90.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 18th, 2009, 09:42 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Has anyone actually replaced an A arm ball joint more than once on the same truck? It seems like a 1 time job. If you burned through more than 1 I would suspect you have suspension geometry issues.
Old September 18th, 2009, 04:58 PM
Antichrist's Avatar
Antichrist
Tom Rowe
I probably could have. The one on my Disco needed replacing at about 175k, I've 250k on it now. So I expect it will eventually need replacing again.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
90, disco
Rear A-Arm Frame Brackets..etc TDI Guy Wanted 14 February 16th, 2006 09:15 AM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
1996 Disco 35s, locked, etc... WBDISCO For Sale - Vehicles 0 November 2nd, 2005 10:41 AM
Rear Suspension Buckon37s For Sale - Parts 5 October 10th, 2005 10:58 AM
