Rear stub axel threads worn - Defender Source
Old October 14th, 2006, 01:22 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
So I have had a problem with my rear wheel bearings comming loose... on a 110 with disks.
While repacking the rears yesterday I noticed the stub threads (on either side of the flat section) where the inner washer pushes against the bearing, were worn and that it allowed the flat sid of the washer to move a couple degrees in either direction. The washer is the thicker version. This is the inner washer not the one in between the nuts.
Could the worn threads on either side of the flat section on the stub axel be causing the wheel bearings to become loose? Mabye skrewing up my preload? I have to crank hard to get the preload correct... no greessy hub wrench... 12in skrewdriver and some muscle, and it is not too tight, I'm getting it just right.
any place to get a sal. rear stubs for decent $$??
thanks
Old October 15th, 2006, 10:39 PM
redrover
Guest
Posts: n/a
The inner washer has a tiny amount of rotation like you felt. That washer is not going to turn beyond its play thanks to the flat spot.. Thread wear wouldnt affect that. But thread wear would be bad for the nuts holding. Any pics? Is the grease seal recessed 4mm? If not ,you wont get a real preload reading. Also do you tab the outer washer in and out to prevent the nuts from loosening? JP
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
