So, as most of you know, there are two tubes attached to the rear step bumper that slide through the cross member and a bolt goes into these tubes from under the vehicle. One of mine broke off when I removed the bumper, and try as I might, I have not been able to get the broken piece out of the hole. This is surprising as I have drilled clear through it, and there is not much stuck in there, but it sure has a grip!
Anyway, as a last resort I am about to drill it out and re-tap the hole, but I don't know what size & thread the bolt is. Naturally the parts catalog doesn't tell you (that would be way too easy). The BMW catalog always gives the bolt size and thread, but LR never does :angry
Anyway, if anyone knows what size it is, that would be most helpful, otherwise I am going to have to figure it out myself, which isn't easy since I don't have a thread gauge that will fit in the hole, and I don't have the other bolt that i removed any longer.
Thank you for your help!
