Rear Spring seat wedges? - Defender Source
Old July 7th, 2011, 10:39 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Is there a source for wedges or angled spacers to correct the tilt of the lower spring seats when an upward pinion angle is used on the rear axle?
Old July 8th, 2011, 05:28 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Some big fat washers under one of the bolts?
although that won't "spread the load" nicely would it.
Old July 8th, 2011, 06:49 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
If you have enough of an upward tilt to need a *wedge* you are running the pinion at an angle that might work nicely for a double cardon drive shaft but will have a negative effect on the oiling of the outer pinion bearing. Not just making that up........
RTE used to make wedges out of the same stock they made spacers out of.
Matt Browne
Old July 8th, 2011, 08:09 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I am running a double cardon MB. The 88 coiler chassis is so short it's necessary unless I ran really short springs. My 3rd's are built on series housings so I have the fill on the 3rd which lets me overfill it a bit for the pinion. I'll post a photo later.
Old July 8th, 2011, 09:32 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
If you can make a simple drawing Raloid Tool on 236 at the Mechanicville/Halfmoon line will make them for you. There work is good and fairly cheap.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
exmod110's Avatar
exmod110
Don Lang
try any alignment shop for leaf spring caster shims and modify to fit between the seat and the axle?
85 exmod 110 rhd 300tdi
Old July 8th, 2011, 01:38 PM
TS888's Avatar
TS888
Tony Sims
1984 110
Not to open a can of fabrication worms, but might it not be better to cut the axle tubes, rotate and re-weld? It wouldn't be a huge job.
Tony
1984 110 "Smokey" (sold)
Old July 8th, 2011, 01:45 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Ummm, yes it would.
Old July 8th, 2011, 02:05 PM
TS888's Avatar
TS888
Tony Sims
1984 110
I guess it's all relative to your comfort level. I'd chop and weld in a heartbeat.
Tony
Old July 8th, 2011, 03:03 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Any specific reason you used a series 3rd member housing, are your running coiler axle tubes or series.....Just curious.
Old July 8th, 2011, 04:03 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I bought them already built as a pair with gears and the compressor, that's all. Full coiler suspension and axles.
Old July 8th, 2011, 04:11 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Why would you have to cut the entire tube? Just take the mounts off and rotate them to where you need. Other than that, get creative I guess?
Old July 8th, 2011, 04:15 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Sounds like he just likes to cut and weld things.
Old July 8th, 2011, 04:41 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
Try Blue Torch Fab if you want steel degree shims. Perhaps those would work?
http://www.bluetorchfab.com/Search.aspx?q=degree+shims
Old July 8th, 2011, 09:54 PM
Kevin:
No personal experience with this, but if you are set on running it this way, then why not "keep it simple" and just weld on new perches at the correct angle.
like these:
http://www.yrm-metal-solutions.co.uk...acket-38-p.asp
just an idea.
Old July 10th, 2011, 05:51 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
I think I also have some wedges if you want to try it.
Personally I'd get rid of the DC shaft. I'd be surprised if it really has more angle capacity than a conventional shaft (I didn't say stock shaft). Expensive. Hard to maintain. Hard to repair. Weaker. Generally create more vibrations than they cure. Force you to compromise suspension geometry and drive line angles. Make you have to overfill diffs in an attempt to counteract poor pinion oiling. I could go on and on.
Matt Browne
Old July 10th, 2011, 05:59 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
MB, I've done all the work to get the driveline angle perfect, it's not going anywhere now. The coiler chassis is pretty much impossible to run with a conventional shaft, it pushed 15 degrees at rest. With parallell pinions I got wicked vibes at coast and went through u joints in 4k miles.
Old July 10th, 2011, 06:50 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
Cool. I'd say you've got it sorted then.
Just curious.....is the drive shaft length different with the Designa chassis vs the leafer? I'm doing an 88" coil chassis for an SI and it just seems like I should move the axle back a bit.
Matt Browne
Old July 11th, 2011, 04:17 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Rear shaft length is approx. 23" from mounting surface to mounting surface.
Old July 13th, 2011, 04:42 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Problem solved for 12 bucks. Just need to drill 2 holes.
Freebie...nada...zilch Bestop rear bench seat kolvedic Defender Technical Discussions 1 March 10th, 2006 01:10 PM
Rear Seat Belt Help Andrew Vick Defender Technical Discussions 9 February 9th, 2006 04:59 PM
Surrey top, rear bench seat, and front guard klcarvalho For Sale - Parts 9 October 21st, 2005 12:45 PM
rear roll cage, rear seat, soft top surfd90 Wanted 0 January 12th, 2005 02:59 PM
