Rear Spare Wheel Carrier - Defender Source
Old May 19th, 2005, 09:51 AM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
The rear spare wheel carrier on the 90 Soft Top is rattling a LOT, like, unbearably.
I know the ultimate solution is to with something custom or one of those Mantec/chassis mounted ones, however, I am certain that this original one should not rattle like this.
Other than simply tighting every bolt on it, what is the best way to attend to this?
Nadim
'92 Disco truggy (42"s, ZF, dual cases, ARBs, 30 splined, OMEs, Optimas, Warns, Bead-Locked)
'04 D-90 TD5 ST (33"s, tuned, caged, 1/2 top)
'84 Rangie 2 door classic (32"s, OME, ARB bar & M8000)
'04 Disco II stock
'07BMW G650X Challenge (farkled)
Old May 19th, 2005, 10:34 AM
jabber
m j
110
http://www.roversdownsouth.com/defender.htm
For $8 you can rebuild the hinge.
Old May 19th, 2005, 07:51 PM
4WD-90's Avatar
4WD-90
Christopher Stanish
1994 defender 90
Hey Nadim, you could try to grease the fittings at the pivot points of the carrier, that helped when I did mine. Also check to see if your whole tailgate is loose, you can rebuild those hinges as well. Good Luck! Chris
Old May 20th, 2005, 01:37 AM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
The hinge rebuild kits are SO worth doing! My tailgate was rattling away, driving me crazy, and after the $8 fix, it's quiet as ever.
I highly reccomend it.
Old May 20th, 2005, 04:02 PM
Mark M
Mark Mathews
'94 Beluga Black ST
Do the hinge rebuild. I just did mine a few weeks back and couldn't be happier. I no longer have to lift up on the gate in order to shut it properly.
Old May 21st, 2005, 04:35 AM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
Great feedback guys - much appreciated...
So i'll be needing 2 x the 8$ fix-its? right?
I'll order these, grease the hinges, and see how that works...hopefully it'll be great...if not, I'm contemplating putting the spare flat in the rear with a mount for the Engel on top...ugly, I know, but I'd like to hear something other than rattling
'04 Disco II stock
carrier, spare, wheel
Scorpion Racing Rear Wheel Carrier JohnC The Vendors Loft 13 May 5th, 2006 08:21 PM
Rear Tire Carrier The Wizard Defender Technical Discussions 15 January 6th, 2006 11:29 AM
Rear Spare Tyre Carrier Noises??? adibitar Defender Technical Discussions 7 May 23rd, 2004 07:49 PM
D90 SW rear wheel carrier mdmccallum Defender Technical Discussions 14 January 27th, 2004 02:45 PM
