Rear sliding windows? - Defender Source
Old September 9th, 2005, 12:13 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I recently noticed that since getting back from CO, every time I shut the doors on the D, the rear sliding windows "poof" out (frame and all), and pop back in. Kind of a fun game.
Anyway, how are they attached? I started to pry back the edge and noticed double sided tape of some kind. Which is scary. Is that some form of seal or are these actually attached?
Thoughts?
Old September 9th, 2005, 12:29 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Thoughts?
rivuts. Must have worked loose.
JP
legend in my own mind
Old September 9th, 2005, 01:02 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Thanks JP. Ah yes, rivnuts...
Old September 9th, 2005, 01:17 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
They are actually rivets, not rivnuts. All you have to do is remove the seal around the outside of the window and you will see where the window is held in by about 20-30 rivets. I think they are an odd size rivet. Make sure you get aluminum rivets. Just want to forewarn you, it is a bitch getting the seal back in.
How in the world have I spent this much money and still don't have a running vehicle?
Old September 9th, 2005, 01:24 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Classic. It couldn't be any other way... I'm sure because the seal is 8 years old and sun dried, it will be more than pliable.
Old September 10th, 2005, 11:05 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Yes rivets. Spelling foepaw'
I usually ground down a regular rivet to work and use right stuff instead of the seal.
Old September 10th, 2005, 11:11 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
hey Pendy, what the hell kind of half-assed shop you running?
Old September 11th, 2005, 01:04 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Soft
Old September 11th, 2005, 09:31 AM
maya
MAYAA ABDO
hi
hi
I need help
where can I find fastback for defender 90
Old January 23rd, 2006, 11:30 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Finally getting around to this. What's the easiest method for removing the outside seal? Mine is super brittle and I couldn't find a good place to start without inevitably marring the surface.
Old January 24th, 2006, 08:21 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Awe nevermind. Lack of sleep or something. Captain Obvious slapped me upside the head. Drilling those out is not fun. I found 6 total in the lower corner not even attached.
Old January 24th, 2006, 01:37 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
hey pendy
Are you talking about using right stuff for the outside seal or inside seal?? wouldnt outside look a bit funny? getting that OEM out side seal back in is a PITA. order a new one and it won't break on the way in.
window, windows
Station Wagon 90 110 Sliding Rear Window Fixing Thread R. Kurk Defender Technical Discussions 39 January 30th, 2013 09:58 PM
Removing S/T Front Sliding windows Frankie Carbone Misc. Chit-Chat 3 July 28th, 2008 10:28 AM
soft top, rear bench seat, rear bumper AND alloys(trade) DBZ2009 For Sale - Parts 20 September 10th, 2006 09:00 PM
sw small rear windows mattdh Defender Technical Discussions 1 July 5th, 2004 05:05 PM
» Defender Registry
Blue Mule
don
Pumkin
natas
Add your Defender
