Rear self-leveling unit. - Defender Source
Old June 12th, 2009, 04:29 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Would someone with experience with the rear self-leveling unit be able to comment on its function and if once upgraded to OME springs it is going to still have any effect or not? I got a basic explaination of what it is intended to do but need to decide if I should keep it or not when things start to go back together. It does seem like a very expensive item to replace when it does go bad.
Old June 12th, 2009, 04:50 PM
Keep it. It does not harm and can only help. They are basically free (I just threw two out) if they go bad.
Old June 12th, 2009, 06:57 PM
ajh
Andrew J. Hutton
Is there any down-side to keeping it on? I am also planning on supplemental airbags in all four corners as well. My chassis is finally ready and shipping along with a huge pile of other stuff so hopefully I can start to assemble in about two-weeks. Now I just need to figure out the rest of my bulkhead mods.
Old June 12th, 2009, 07:33 PM
If you go with a huge lift or really flexible suspension it might bind. With 2in OME there is no downside.
Old June 12th, 2009, 08:11 PM
ajh
Andrew J. Hutton
Ok thanks, so will keep it then and just order new gaiters to replace the torn ones. Thanks!
Old June 12th, 2009, 08:27 PM
I mean isnt there no point with the OME 2" (HD)
Old June 12th, 2009, 11:47 PM
It will do a lot less as you will not get to the point where it starts working often, but IMHO it will still work. On my old RRC with 3in RTE springs you could still load it down and after a short ride it would gain back some of the height from the load.
Old June 13th, 2009, 01:06 AM
bjf's Avatar
bjf
barry f
94 ST #395
what is a self leveling unit?
Old June 13th, 2009, 07:40 AM
Mine seems to still work on my RRC, I am not sure to keep it or let it go.
Old June 13th, 2009, 10:57 AM
mattarm's Avatar
mattarm
Matt
1993 D110
is the RRC self leveling unit the same as the boge unit found on the NAS 110?
Old June 13th, 2009, 01:55 PM
Similar, but not the same. The 110 one has an extra ball on it.
Old June 13th, 2009, 03:09 PM
Extra ball ?
Old June 13th, 2009, 03:50 PM
Yes, there is a globe looking thing that looks like a ball attached to the 110 one. I assume it is an extra resivoir.
Old June 14th, 2009, 01:16 AM
bjf's Avatar
bjf
barry f
94 ST #395
ah that is what I just replaced. Ball Joint assembly. Mine was worn out. When I would go over bum[s it sounded like I had no shocks.
Old June 14th, 2009, 01:20 PM
No, that is not what you replaced. You replaced the ball joint that mounts between the A-frame and the axle. The self leveler mounts to a part of the A-frame. The ball shaped res. on the 110 leveler is maybe 6in in diameter.
Old June 14th, 2009, 11:58 PM
bjf's Avatar
bjf
barry f
94 ST #395
Ahhhhh then I have no clue
Old June 15th, 2009, 03:58 PM
ajh
Andrew J. Hutton
I am going to try to attach photos in the future to help show the exact part.
Old July 16th, 2015, 04:48 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
My new-to-me '84 110 has an unusually hi rear end stance without a load & seems to have a very stiff suspension back there - eg, very noisy reactions to small city bumps. Does any of that indicate a failed self-leveling unit? Or when it fails, does the rear end sag or rise or neither???
Old July 16th, 2015, 06:40 PM
Be good to see a picture. Load levelers tend to fail over time and get removed. Is yours still there? If removed, the springs may have been replaced by heavier duty spec units. So you see any paint marks on the springs or numbers/letters different manufacturers mark their springs differently.
Old July 16th, 2015, 07:03 PM
if you have upgraded your springs its function is moot. The idea behind the boge self leveling unit was it enabled the use of softer rear springs for improved ride quality, usually found on county spec trucks.
I hate them just because of the wasted space
------ Follow up post added July 16th, 2015 07:07 PM ------
usually the nose down in the front is because HD rear springs are fitted. HD springs and self leveler dont really work in unison. Are you sure you have the self leveler ?
D110 300Tdi Rear AC unit - NEW artm For Sale - Parts 36 December 18th, 2008 09:09 AM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
