Rear self-leveling unit. - Page 2 - Defender Source
Old July 16th, 2015, 07:45 PM
Originally Posted by evilfij View Post
Yes, there is a globe looking thing that looks like a ball attached to the 110 one. I assume it is an extra resivoir.
http://www.landyrebuild.com/images/boge-cleaned.jpg
Old July 16th, 2015, 07:47 PM
Originally Posted by cowboy View Post
My new-to-me '84 110 has an unusually hi rear end stance without a load & seems to have a very stiff suspension back there - eg, very noisy reactions to small city bumps. Does any of that indicate a failed self-leveling unit? Or when it fails, does the rear end sag or rise or neither???
Most likely someone put in some aftermarket springs that left you with no extension travel.
Old July 16th, 2015, 08:56 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Yes, the self-leveling unit is definitely still there. I even took a whack at the slim (44M?) nut on the rim of the cup that it's set in last night. Will check to see if I can find anything on the springs...
Old September 22nd, 2015, 02:03 PM
cowboy
steven
Just getting set up to change out these rear springs as prompted from the input above - I was unable to find any markings on the installed springs other than being black with a dab of green paint down low on the outside face of one of the coil loops, so I ordered a pair of the oem springs for the with-Boge configuration ( nrc6388 & nrc7000 ) which are definitely coiled from a thinner size (of steel bar?) than what is on there now.
Couple of questions, though:
I'm thinking that I should measure the amount of lift of the springs that are on there now b4 I remove them...where exactly should the measurement be taken?
The new springs are sold as one part # for drivers side & a different part# for passenger side...is that from a RHD point of view or do I dutifully install the driver side part # on my left side?
Old September 23rd, 2015, 10:03 AM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Chunk the Boge unit! Waste of space! In terms of springs being sided…driver's side means DRIVER'S SIDE whether it be RHD or LHD.
Old September 23rd, 2015, 10:59 AM
LRover's Avatar
LRover
J. Michael McCaig
If someone is throwing a good one away, I'd like to have it for a spare and I'll pay shipping. I find it useful when I hook to a heavy trailer. Even with a two inch lift, it helps to level things out with my 110.
D110 300Tdi Rear AC unit - NEW artm For Sale - Parts 36 December 18th, 2008 09:09 AM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
