rear seat install - anyone got photos/info ?? - Defender Source
Old December 2nd, 2004, 12:31 AM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
Question rear seat install - anyone got photos/info ??
I have some (I think) British Atlantic jump seats. Before I start drilling holes and all, I thought to ask a question or two:
1. Can anyone post photos of how the seats look attached.
2. Should the tub wall be reinforced where the seat bolts are to go?
3. Verticle aspect of the seat attachment - the front 2 bolts: should this piece of metal be slightly angled as mine is, or should it mount flat to the tub wall?
Any insight or advice is really welcome.
Name:	seat position.JPG
ID:	1969   Click image for larger version
Name:	front 2 bolt holes.JPG
Name:	angled front.JPG
ID:	1971   Click image for larger version
Name:	rear 2 bolt holes.JPG
Old December 2nd, 2004, 10:47 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Paul the front piece should mount flat to the tub wall.
The seats you have arent the typical inward facing seats i have seen. what are they out of?
I would try and flatten the front portion if possible and put a piece of L bracket behind that porton On the top of the tub i woul put a wide metal strip for reinforcement. I dont see that the seat bolts to the gunnel is there a provision for that?
If not I would try and mount to that area as well for stability.Are you using your stock seat belts?
Make sure you use the correct grade bolts and have a heavy reinforment for them.
Old December 2nd, 2004, 04:18 PM
Defender50th's Avatar
Defender50th
James
'94 NAS AA Yellow
Hi,
Here are a couple of pics i have of my station wagon. As you can see under the wheel arch where the seats bolt down there is not any renforceing but it is probaly best to put some. The black bar is where the seat belts bolt onto, this is going to take all the strain in a crash.
Best regards
James
ID:	1980   Click image for larger version
Name:	int back un front.jpg
Rear Bench Seat + hardware Chaucer For Sale - Parts 8 September 29th, 2005 12:16 AM
Side Brackets for Rear Bench Seat & Rear Seat Belts zed111 Wanted 2 August 16th, 2004 12:33 PM
Side Brackets for Rear Bench Seat & Rear Seat Belts zed111 Defender Technical Discussions 2 August 13th, 2004 05:33 PM
Wanted: Forward facing rear bench seat zed111 Wanted 0 July 26th, 2004 01:52 PM
