Rear seat belts stay locked - Defender Source
Old July 2nd, 2013, 10:42 PM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
I recently replaced the rear bench seat belts with compatible ones out of a discovery. Once they were bolted in place they worked fine until the first test drive. Now they are both locked in retracted position (inertia belts) and can't be pulled out to buckle someone in.
Is there a trick to getting these to work or are they simply broken? Totally stumped by this one.
Old July 2nd, 2013, 10:59 PM
The discovery ones are shorter so long term you need to lower the shoulder mounts (a simple piece of flat bar with two holes drilled will do) or lengthen at the bottoms.
Short term, unbolt the shoulder mounts and allow the belts to retract fully which will then allow them top release. Make sure the kids know not to fully extend them until you do the proper fix
hth
charles
Originally Posted by pendy
I'm here for the D's
Old July 2nd, 2013, 11:01 PM
This: http://www.defendersource.com/forum/...belt+discovery
Old July 4th, 2013, 04:41 PM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
This makes sense and was really helpful. Thanks! I'll reproduce the same brackets and update with my results.
Old August 14th, 2013, 02:48 AM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
Charles, thanks for the tip. I ended up building extension brackets in an almost identical pattern and it worked great!
Old August 14th, 2013, 10:30 AM
Great. It really is the easiest fix.
Rear Bench Seat + hardware Chaucer For Sale - Parts 8 September 29th, 2005 12:16 AM
Lap seat belt for the rear - flip up seat paulb Defender Technical Discussions 2 January 27th, 2005 03:43 PM
Side Brackets for Rear Bench Seat & Rear Seat Belts zed111 Wanted 2 August 16th, 2004 12:33 PM
Side Brackets for Rear Bench Seat & Rear Seat Belts zed111 Defender Technical Discussions 2 August 13th, 2004 05:33 PM
Rear seat belts jward Wanted 11 October 4th, 2003 03:38 PM
