Rear Seat Belt ...Help! - Defender Source
Old January 26th, 2011, 02:21 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
I am planning on adding a rear bench seat to the load space in my NAS D90 SW. I like the seat belt set up on the new TD5 Defenders. I am looking for the part numbers on the parts labled 1 thru 5 on the plan attached. The bracket is installed in the picture. Can someone help me with the part numbers and maybe a good source for the parts??
thanks
Name:	TD5 bracket drawing.jpg
ID:	35187   Click image for larger version
Name:	TD5 bracket.jpg
Old January 26th, 2011, 05:06 PM
bjf's Avatar
bjf
barry f
94 ST #395
there is also a POE part you could use that works with the stnadard bench seatbelts made for a ST
Old January 26th, 2011, 05:21 PM
Reese_D90's Avatar
Reese_D90
Reese
I will be getting the belts and hardware with the rear bench from a ST. I am concerned about the upper attachement point on the SW. This connects to the cage on the ST. What POE part are you talking about? RN sells something for the upper point on the front belts. Im not sure that that will work though.
Old January 26th, 2011, 05:41 PM
bjf's Avatar
bjf
barry f
94 ST #395
In POE trucks that didn't have the rear cage, there was a bracket mounted on the upper section of the top in each corner for the I know Read on the board has it in his POE. ECR makes one too for their projects where they convert SWs from fold down to bench seats
Old January 27th, 2011, 07:46 AM
Reese_D90's Avatar
Reese_D90
Reese
Does anyone have access to a 2007+ D90 parts book??
thanks
Old January 29th, 2011, 11:35 PM
blenkush's Avatar
blenkush
Severin Blenkush
97 D90 LE, 10 Lotus Exige S, 05 LR3
Upper seat belt mount
I installed a bench seat in my SW and had a mount made for the upper part of the shoulder belt. It ties into the roll cage under the wheel well. It's basically part of a roll cage welded to a plate with two triangular supports. Works well and did not require any permanent mods to the vehicle.
Cheers,
Severin
ID:	35291   Click image for larger version
Old January 30th, 2011, 09:50 AM
ECR posted a picture of this a year or two back... Maybe Josh can find it.
Old January 30th, 2011, 10:05 AM
Reese_D90's Avatar
Reese_D90
Reese
Thanks guys. RDS helped me out with the part numbers. Now I just need to decide if this is the direction to go. It seems like the most sound direction when fitting a rear bench seat in a SW. I like the idea of a LR engineered seat belt set up. (I cant believe I just wrote that).
Rear Seat Belt Brackets zed111 Defender Technical Discussions 11 August 6th, 2007 02:45 PM
Rear Seat Belt Help Andrew Vick Defender Technical Discussions 9 February 9th, 2006 04:59 PM
Need Rear Seat Belt Receiver for D-90 ST YellowD90 Wanted 0 November 5th, 2005 11:54 PM
Lap seat belt for the rear - flip up seat paulb Defender Technical Discussions 2 January 27th, 2005 03:43 PM
