rear seal is wet - Defender Source
Old September 13th, 2005, 04:57 PM
jblieb
john
rear seal is wet
my rear seal is wet. It does not appear to be leaking at this time onto my garage floor. Any idea what it'll cost to replace this?
thanks
john
Old September 13th, 2005, 05:05 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Last quote from a good independent rover shop was upwards of around $1,100. Dealer wanted areound $2,800.
EwS
Old September 13th, 2005, 06:37 PM
jblieb
john
how long can it be wet before needing to be replaced?
Old September 13th, 2005, 08:24 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
I`m still new to this.... rear seal? what is it?
Old September 14th, 2005, 09:52 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
The rear main seal on the engine.
Can't tell you how long it you can leave it. If it's not a huge leak, I would just keep an eye on it.
EwS
Old September 14th, 2005, 10:01 AM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
Are you sure your problem is the rear main seal?
Rear Main Seal Heath Defender Technical Discussions 1 March 15th, 2007 11:13 PM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
Rear main seal replacement howellm70 Defender Technical Discussions 4 May 20th, 2004 07:33 AM
