Rear/Safari Door Jam Switch - Defender Source
Old December 7th, 2008, 03:36 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
So, as many of you know, the NAS 110 does not come with a door jam switch to turn on the dome lights when you open the rear door. I would like to add one, and was going to do something custom, but I think the D90 SW came with this from the factory. I could be wrong, but if any of you have a SW with this, I would very much appreciate a picture of where exactly it fits, and most importantly, what is attached to the door to press it in when it is closed. If someone could post a pic that would be great. Also if anyone has already added this to their rig, I would love to see how you have done it.
Thank you in advance for any help.
Old December 7th, 2008, 05:31 PM
Chaucer
Will
93 110 | 97 90
Not the greatest pic, but here you go -
Old December 7th, 2008, 05:59 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Perfect, thank you. That is along the lines of what I was planning, but was curious how they had done it.
door, switch
Wiper motor limit switch replacement LenB Smaller Projects 5 June 7th, 2012 07:29 AM
Headlight Switch Issue, any ideas? januconn92 Defender Technical Discussions 1 July 24th, 2005 11:53 AM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
