Rear propshaft with CV joint question - Defender Source
Old October 29th, 2013, 11:35 PM
anfonee1's Avatar
anfonee1
Jeffrey
1984 D90 RHD SW
I ordered a new rear propshaft for my defender 90 with 300tdi and it came with a CV joint on it. I have seen on a lifted NAS rover I did work on a piece that goes between the brake drum/output shaft and this prop shaft that adapts the two patters to eachother but can not find one in parts listings. does anyone know what I am talking about???
Old October 30th, 2013, 05:24 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
What year/model Defender? OE, aftermarket propshaft?
I'm pretty sure no OE D90 has a double cardan u-joint. Some aftermarket propshafts require the adapter which is supplied with the shaft.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old October 31st, 2013, 12:50 AM
owen's Avatar
owen
Owen Jones
Yellow`95 D90 ST #2188
Stock driveshafts have regular universal joints. Aftermarket driveshafts often come with double cardon.
Older aftermarket propshafts may also need an aluminum adaptor at each end to change the yoke bolt pitch. Tom Wood's shafts have not required adaptors since a couple of years ago.
Note that the axle setup for a double cardon is diferent from UJ setup to avoid drive train vibration and resulting wear
The DC joint should be on the transfer case end of the shaft. The axle must be rotated to align the diff pinion shaft with drive shaft.
The Tom Woods website has a good writeup on the diferences in axle setup between the two types of shaft joints
IMHO, If you can, get replacement stock UJ type driveshafts and avoid the setup and maintenance hassle of a switch to double cardon. Especially true if you have stock (no) lift.
"I think you need a little weatherstripping - right here..."
1987 LHD 90 2.5td broadstone For Sale - Vehicles 4 May 21st, 2013 07:27 PM
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
Dingbat question on rear NAS bumper fitting smob Defender Technical Discussions 11 April 22nd, 2011 03:48 PM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear Dome Light Stays On thug1313 Defender Technical Discussions 5 November 1st, 2004 08:33 AM
» Defender Registry
Rosa
fruitpunch
Susan
bluwave
Add your Defender
