Rear Pinion slack - Defender Source
Old September 12th, 2005, 03:39 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Rear Pinion slack
Hey all. I just replaced a bad bearing in the rear pinion. I noticed that while I was pulling the bearing out that the pinion would move in and out about a half inch. Is that normal? I plan on removing the diff tomorrow to see if there is any damage and to try and figure out why I still have a high pitched whine at 35 and 55 mph. As well as a clunking noise thats speeds up with wheel speed. My initial thought was that the center diff was just clunking since I have been driving around in frontwheel drive for the better part of a month.
Jimmy Buffett
Old September 12th, 2005, 03:57 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Did you pull on the shaft after removing the flange? I think there should be a spacer in after the flange.
John C.
Old September 12th, 2005, 04:46 PM
flippedrover
Tyler
'94 D-90
I left the shaft in and pulled the bearing and oil seal. I put the spacers and stuff back in again.
Jimmy Buffett
Old September 12th, 2005, 09:50 PM
Are you saying that you could move the shaft with the outer bearing out?? That sounds reasonable. The pinion could move up the ring gear as the inner bearing unseats.
You shouldn't just replace one bearing. It would be pretty hard to set the bearing preload properly.
Old September 12th, 2005, 10:07 PM
flippedrover
Tyler
'94 D-90
Yeah. I'm pulling it out and going to replace them both.
Jimmy Buffett
ac
rear pinion angle correction KevinNY Defender Technical Discussions 11 April 6th, 2007 03:35 PM
Rear Pinion flippedrover Defender Technical Discussions 13 August 14th, 2005 08:43 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
