Rear Pinion seal question - Defender Source
Old March 1st, 2016, 01:18 PM
squidface's Avatar
squidface
justin whalen
1988 110
I have a 1988 110 vin# SALLDHMB7EA338379 2.5L 4 cylinder diesel and I'm finding different info on pinion seal replacements depending on the axle. anyone have any insight on part number or how to tell what axle i have etc.
thanks in advance
j
Old March 1st, 2016, 02:12 PM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
Hi Squdface
I'm assuming it's a Salisbury axle and hasn't been changed over the years?
Have a wee peep here to see what it looks like....later rear axles/ Discovery axles look the same as a front axle diff.....also you see all Defender part numbers on this site,for a spot of light reading lol.
http://www.allbrit.de/UNI.cfm?PAGE=755834&SPRACHE=EN
There's two different seals....I'd order both and replace with which one you find in there.
AEU 2515 is a leather seal(soak overnight in EP90) which is from the early axles..probably yours
or
STC 4401 a later rubber oil seal with a mud shield.
Go for the make 'Corteco' or 'Bearmach' or even Land Rover (seals made by Corteco also) and not Britpart IMO
All the best
200tdi Ex British Army 110 Hardtop 139142kms
2.286 Petrol Series 3 Lightweight 75,043kms
3.2DiD Pajero 266,000kms
Yamaha XTZ660Z Ténéré 58112kms
Gas Gas 300EC Ohlins Enduro Moto.
Old March 1st, 2016, 02:29 PM
squidface's Avatar
squidface
justin whalen
1988 110
thanks for the info. i owe you a beer
j
Old March 2nd, 2016, 12:28 PM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
You're most welcome .....I'm Irish......it'll have to be a pint of Guinness
Old March 2nd, 2016, 03:39 PM
Do not use the leather seal. They suck. If you search on this website, there is a replacement seal from a dana 60 that works much better. Also, be sure to clean your breather as that is a cause of many many pinion leaks (you may not need a seal at all, but with the leather ones they seem to leak no matter what).
Old March 8th, 2016, 04:44 PM
squidface's Avatar
squidface
justin whalen
1988 110
good call on the breather. it was filthy
Old March 8th, 2016, 06:26 PM
In addition to the breather, watch/check the actual flange on the pinion. If it's scored at all, get the Speedi Sleeve #CR 99187 (this will fit a Sals) to put on the flange before you install it in the new seal.
Pinion Seal Leak, Salisbury Diff Doug Defender Technical Discussions 18 August 8th, 2016 03:07 PM
Which pinion seal for rear - FRC8220 / FTC5258 nathanwind Defender Technical Discussions 4 September 26th, 2014 10:07 AM
pinion nut torque specs and seal question wantone Defender Technical Discussions 0 May 30th, 2012 12:11 PM
Rear pinion seal bjf Defender Technical Discussions 7 April 13th, 2012 01:57 PM
Sals. pinion seal D90user Defender Technical Discussions 0 March 15th, 2007 01:01 AM
