Rear pinion seal - Defender Source
Old April 13th, 2012, 03:15 AM
bjf's Avatar
bjf
barry f
94 ST #395
In the parts manual there are two part numbers for the rear pinion seal. The first seal is good for a certain set of numbers as is the second seal. I asked the dealer what the number corresponds to since it didn't match my vin and the said the axle housing is stamped. Now my rear housing has long ago turned orange and I can't find anything stamped on it. The dealer only had the seal for the second set of numbers. I think it has something to do with coarse vs fine splines or some crap. My truck is an early 94. (395) Does anyone know what seal I should have?
Old April 13th, 2012, 03:58 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Barry,
You're going to need this # as there is no other way to know which axle you have under there. It’s a PITA to get as well, sorry. If you’re unlucky then its laser etched from a series of dots which make it hard to read at the best of times like mine, worse if its obscured. If you’re lucky it will be stamped just like a VIN # on the frame. Good news is that unless your surface rusts is really bad then a rub with some medium and then fine grit abrasive paper should make it still readable and on the rear it should be the right way up.
Look at the 3 pics of my front axle. They try and zoom you in to where it is located. I can't get good pics of my rear one at the moment due to the tank cradle being in the way. The front and rear are the same though, just reversed.
Now you know where it is you should be able to find it. It’s normally in a similar format to the T-Case number with 2 numbers, followed by a letter to denote the type and then the serial numbers.
HTH
Ian
Name:	Axle No 1.jpg
ID:	50227   Click image for larger version
Name:	Axle No 2.jpg
Name:	Axle No 3.jpg
Old April 13th, 2012, 07:37 AM
Could you clean it the best you can, tape some thin white paper over the axle, then shade a pencil over it to try to get the number displayed more prominently from the etching?
No way you could buy both and return the wrong one, right?
Old April 13th, 2012, 08:31 AM
Grover's Avatar
Grover
The CSI approach is a good idea...it works...
Cheers...
Old April 13th, 2012, 10:24 AM
bjf's Avatar
bjf
barry f
94 ST #395
The dealer only had the newer one in stock.
Most of the rust on my truck hit the back hard. The rear axle has no paint and I long ago replaced the fuel cradle because it turned to dust.
I now have an idea where to look but I doubt I will find it. Actually did they use the laser method in 94?
Old April 13th, 2012, 12:19 PM
bjf's Avatar
bjf
barry f
94 ST #395
Where would it be on the rear axle? If it was on the front of it then it is long gone.
Old April 13th, 2012, 12:32 PM
grnrvrs's Avatar
grnrvrs
Paul
88
On my 88 and 110 rover stamped the rear axle ID on the back side of the axle case tube to the left of the diff. YMMV
1970 SIIA 88, Sold
Old April 13th, 2012, 01:57 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
On the Driver's side facing back. Same as the front just flipped like the axle casing is. Older ones are stamped and easier to read, newer ones are punched out of dots like you see on mine and a Biatch to even see let alone read. Just clean the area with some abrasive paper and you should find it.
Countersink Oil Seal on rear of Rotor/Hub founD90 Defender Technical Discussions 13 July 2nd, 2011 07:04 PM
XCase Rear Output Seal Viggen Defender Technical Discussions 3 August 26th, 2010 11:49 AM
F/S Rear Door Seal SW Rugbier For Sale - Parts 0 April 11th, 2010 07:29 PM
Rear Main Shaft Seal, how far back to drift in? Neil McCauley Defender Technical Discussions 4 September 12th, 2009 01:28 PM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
