rear pinion angle correction - Defender Source
Old April 5th, 2007, 04:37 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I have an 88" coiler and thus a very short rear prop shaft. I run a tom woods rear shaft, standard 2 ujoints. I am getting drive vibes when I let off the gas for just a second at any speed over 40 MPH or if I feather the gas at speed. I know the answer is to get a CV rear prop shaft but the question is how do I get the rear pinion in line for it. I measured everything with a slope finder and have a 15 degree working angle on the tcase joint and an 11 degree working angle on the rear joint acounting for 2 degrees of pinion rotation at cruise. I'd prefer to not spend a fortune of course. I read in the F.A.Q. that someone had simply installed the rear triangle shaped trailing arm bushings from the front instead of the rear and thus effectively shortened the rear link by a half inch. Is this felt to be an OK thing to do? What is the relation of link length to pinion angle? 1/2" equals x degrees? I need 8 degrees of correction to get within 3 degrees of in line with the tcase at the min. I guess using an a arm extension from RT could be done in addition too. At these angles now I am need of new joints every year at the minimum. I have RT rear links and could get Keith to cut and reweld them too I guess.
KB
Old April 5th, 2007, 04:51 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Kevin,
I made a set of trailing links to the correct length so my diff was at the angle needed. I measured by taking the links off then reconnecting them to the axel only. Then with the axel suported with ratchet straps I move the axel forward untill I had the desired pinion angle. I then measured how much shorter (or longer) the link had to be by putting it up nect to the frame bushing and checking the difference in length.
Hope that makes since.
Keith at Rover Tracks sell a trailing arm that you can shim to the correct angle.
Cheers
MH
--Benjamin Franklin
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
KB
In high lift applications of 88 coilers we have done the following:
Installed corrected trailing arms and done CV shafts. This works great in a 4 speed car, and is just OK in a 5 speed car (still will get some slight growl on a no load situation).
We have also dropped the gearbox crossmember some to reduce the driveline angle and that cured most of the stock height 5 speed 88s.
The ultimate cure for some of the taller rigs, like the V8 Lightweight, was to move the engine forward to gain rear shaft length.
Sadly there is no simple answer due to the short wheelbase on the 88s.
Good luck,
ECR
Email:
Old April 5th, 2007, 08:59 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Kevin
I have a spare set of stock trailing arms if you would like to play with a set and see what your truck needs. I don't know if it will help you any but you can also compare them to the HD ones I have since they are without a body over them at this point.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old April 5th, 2007, 09:40 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Thanks Eric, let me talk to Keith tomorrow and see what he says first.
Old April 6th, 2007, 02:26 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
kEVIN, i MOVED MY TRANS FORWARD ABOUT 1.5 INCHES. THTS WITH THE 5 SPEED AND LT230.. mY REAR SHAFT IS ALMOST PERFECT.
Legend in My Own Mind.
Old April 6th, 2007, 10:14 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Ideally that is the answer Randy, especially with the room the perkins gives you.
Old April 6th, 2007, 11:57 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
If it only takes 1.5in, why not move the rear axle backwards?
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 6th, 2007, 12:09 PM
kiefffff's Avatar
kiefffff
Keith Rider
1994 Portofino ST: #217
Kevin - Since you have the RT rear links, have you played with the spacers? Do you currently have them all in or none?
I had a similar problem and this is what Steve suggested.
Old April 6th, 2007, 12:31 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Kevin, what t-case and trans will you have? IF you do my setup, you will have to move it just because of the shifters... IF not, the adjustable rear links will do the trick. I needed them on my d-90... I have the RYM units and they let me run a stock d-shaft with a 3" lift and no vibs at all...
Old April 6th, 2007, 01:02 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Sorry for the confusion, by RT I meant RoverTracks not Rovertym. I spoke to Keith and he had me take a bunch of measurements in the horizontal and vertical to plug into CAD and come up with the perfect length.
Randy, I am running a series tcase and gearbox.
Old April 6th, 2007, 03:35 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
BTW could someone tell me the working length of a stock D90 rear prop shaft?
Castor correction and rear end steering D90user Defender Technical Discussions 0 August 12th, 2006 02:26 PM
Rear Pinion slack flippedrover Defender Technical Discussions 4 September 12th, 2005 10:07 PM
Rear Pinion flippedrover Defender Technical Discussions 13 August 14th, 2005 08:43 PM
front pinion angle ?? TDI Guy Defender Technical Discussions 8 April 11th, 2005 08:44 PM
