Rear Pinion - Defender Source
Old August 9th, 2005, 01:00 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Rear Pinion
Hey all. I am going to replace my leaking pinion seal. What's the torque for it? I can't find it on here.
Jimmy Buffett
Old August 9th, 2005, 09:26 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
are you referring to the 10 bolts hold the differential to the axle housing? If so it's 40 Nm or 30lbf/ft. hope that helps.
Old August 9th, 2005, 10:28 PM
flippedrover
Tyler
'94 D-90
The one big bolt that is in the middle of the flange from the drive shaft.
Jimmy Buffett
Old August 9th, 2005, 10:46 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
From the workshop manual, it looks like it's 130 Nm. Convert that here if you need to www.convert-me.com
Old August 10th, 2005, 07:05 AM
flippedrover
Tyler
'94 D-90
Cool.
Jimmy Buffett
Old August 10th, 2005, 02:14 PM
hmmm, I would check with Trevor on this one but when I did mine the place that installed the R&P told me to note the tork required to remove the bolt, then use that as a guid to refit it. THere is a crush sleave in there and you don't want it to be too loose or too tight. This was the advice given too me by 2 different shops, and they also said o make sure there are no burs or anything in there that would mess up the new seal. When I did mine it took a bit more then 130 Nm to get it off, and I put it on with the same torc, I have just finished a 3oo mile round trip and it ran fine.
Old August 10th, 2005, 03:41 PM
If it is a Rover style diff, there is no crush sleeve. It should done up really tight. You can't really overtighten. The manual specification is meant to be enough to prevent it self loosening.
It is scary that shop say things like that. Makes you wonder if they have ever seen the inside of a Rover diff....
Old August 10th, 2005, 04:30 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
There are 2 styles of pinion shaft used on the Rover Diff. If it has a big nut the torque is around 100 ft/lbs, if it has a 12mm bolt that threads into the pinion shaft, the torque is around 60 ft/lb.
Rob
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old August 11th, 2005, 07:48 AM
flippedrover
Tyler
'94 D-90
Cool. Thanks guys.
Jimmy Buffett
Old August 14th, 2005, 10:38 AM
flippedrover
Tyler
'94 D-90
I noticed while I was trying to replace the rear pinion seal that there was a lot of play to the drive flange. Since I don't have the right size socket at the moment to remove the big nut my question is this. Is there a bering in the pinion or is it just the seal that keeps everything from moving around?
Jimmy Buffett
Old August 14th, 2005, 10:47 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Absolutely there is a bearing for the pinion gear !
Old August 14th, 2005, 01:35 PM
flippedrover
Tyler
'94 D-90
Ok so can anyone tell me the part number for the pinion bearings?
Jimmy Buffett
Old August 14th, 2005, 08:09 PM
If the nut is tight and there is play, a pinion bearing is gone. You need to pull and disassemble the pumpkin to replace the pinion bearings. You need a press or the special tool to replace the outer races.
Old August 14th, 2005, 08:43 PM
flippedrover
Tyler
'94 D-90
Hmm..I was told that I can replace the outter bearing without removing the diff.
Jimmy Buffett
rear pinion angle correction KevinNY Defender Technical Discussions 11 April 6th, 2007 03:35 PM
Rear Pinion slack flippedrover Defender Technical Discussions 4 September 12th, 2005 10:07 PM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
