Rear oil seal or bolt leak? - Defender Source
Old May 29th, 2015, 08:18 PM
scrubs
henery
1974
http://www.defendersource.com/forum/...1&d=1432945038
ID:	121809   Click image for larger version
Old May 29th, 2015, 08:32 PM
can't tell clearly from the picture, but it looks like a rear main seal leak to me.
Old May 29th, 2015, 08:41 PM
scrubs
henery
1974
Thanks, wasn't too sure, no oil under the seal but oil around the bolts .
Thought seal had picked up oil from clutch n left it there.
I've never seen only read about both.
Old May 29th, 2015, 09:20 PM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
what engine? the 2.x engines like to give up on the oil seal. Rarely have play, just has a bad seal. Important to replace so you don't wear the crank to where it won't seal anymore.
Old May 29th, 2015, 11:34 PM
scrubs
henery
1974
Thanks for replys, going to replace the seal,too close not too.
Just didn't know what a leaking one should look like,the bolts have oil under them where the seal appears not too.
Old May 30th, 2015, 10:46 AM
DefenderMd's Avatar
DefenderMd
Ben
Yea.. I would agree with that course even if there was no oil. Once you unbolt the seat box... replace the rear main seal and probably the throwout bearing. To easy not to. Also the transfer case rear seal (going into the brake). they weep and contaminate your parking brake and they're easy to get at and replace when you have the T case out. Heck.. they're pretty easy with the T case in if I remember correctly.
I'm debating doing the same. I have oil accumulate on the bottom of the flywheel housing.. but it seems to be just weep from the oil pan gasket. But it could be both. No drips on driveway. Just a lubed chassis.. corrosion resistance and aerodynamics at this point.
Old May 31st, 2015, 12:12 PM
scrubs
henery
1974
Say, dose the plate have to be removed?
Won't budge n not too interested in prying.
Pinion Seal Leak, Salisbury Diff Doug Defender Technical Discussions 18 August 8th, 2016 03:07 PM
Oil Leak from the master seal on a 2.5 Korongo Defender Technical Discussions 3 July 27th, 2012 04:13 PM
Oil Leak..Oil Pressure Switch Failure? tebby Defender Technical Discussions 2 December 19th, 2010 03:16 PM
leak at front engine mail seal (due to vibration?) => two questions? MonLand Defender Technical Discussions 23 August 31st, 2006 09:30 AM
