Rear marker light - Defender Source
Old November 11th, 2012, 05:21 PM
bneri's Avatar
bneri
1994 NAS D90 soft top
Rear marker light
I have a malfunctioning rear marker light -- I have done the basic bulb change which didn't work--what would be my next step? Thanks
Old November 11th, 2012, 05:39 PM
Fuse?
Is the contact clean?
Was the old bulb broken?
Old November 11th, 2012, 06:29 PM
Corrosion is suspect #1!
Old November 11th, 2012, 06:32 PM
maleger
Marc-Andre Leger
The wires rund behind the rear wheel, subject to all kinds of hazards. I would also look at the state of the wires themselves.
Old November 11th, 2012, 09:24 PM
bneri's Avatar
bneri
Thanks everyone--I suspected the wires as well when I was changing the bulb (which was not broken, my first clue that this was going to be more involved) as they looked slightly corroded..is that easy to fix? I'll also look into the bullet connectors.
Old November 11th, 2012, 09:51 PM
bneri's Avatar
bneri
Another question, if it was the fuse giving the problem, wouldn't the same side front marker be out as well? (it is functioning fine) I was under the assumption that both of those lights are controlled by the same fuse.
Old November 12th, 2012, 01:34 AM
sro
Sam Odio
2008 LR2
Yes both lights (and the side lights) are controlled by the same fuse.
ht
rear light electiral hook ups paulb Defender Technical Discussions 25 January 19th, 2010 03:25 PM
Light disaster! rustydefender Defender Technical Discussions 11 December 30th, 2005 03:34 PM
Rear turn signal light tron Defender Technical Discussions 3 December 5th, 2005 11:02 AM
Rear Dome Light Stays On thug1313 Defender Technical Discussions 5 November 1st, 2004 08:33 AM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
